Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
Freezer Door Pops Open
My GE Profile Arctica's Freezer door pops open slightly loosing its' seal when I close the right-side door causing the freezer to rise in temperature. What can I do to prevent this from happening?
  • 32 Answers
Get stronger magnets.
Posted on Aug 08, 2009
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
The freezer part keeps popping open whenever you close the fridge part. How can I fix this?
The magnets in the freezer door arent making good contact, try adjusting the front legs up to make the fridge lean back slightly
Nov 25, 2009 | GE Profile Arctica Stainless Steel Top...
When we close the refrigerator door (side-by-side unit) the freezer door pops open slightly. The unit is about 14 months old and the seals look fine.
There is something not fully in place holding the door from closing completely. It doesn't take much. You should be able to feel slight resistance when opening if it is seated properly. The cavities are connected so when you close the door fast the air pressure moves from one to the other and pops the door open.
Oct 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer door opens When you close refir. door
The freezer door is relatively light weight, and when the fresh foods door closes, the air has to go somewhere and the easiest escape route is to momentarily pop the freezer door open. The door should close again quickly. If is does not, make sure the freezer door liner is not touching the top or bottom, causing dragging resistance, and make sure that the front leveling legs are raised up so the door closes by it's self when released from a 45 degree opening. Sometimes the hinge side gasket rubs and holds things up also, especially if that area was cleaned. If that is the case, rub a film of wax on the hinge side gasket to lubricate it. Additional weight in the freezer door will also help.
Oct 27, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
383 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
