Question about Asrock K7S41GX Motherboard
Upgrading processor i've just bought an athlon xp 2400+. it says on the asrock website it is compatible but i can't get it to work. i'm running an duron 1.3ghz. i've changed fsb settings to 266mhz but no joy. is there anything special to do when you change cpus
  • 1 more comment
  • mike wright Jun 14, 2007
    so does the ram speed have to match the fsb settings. i'm sorry the last part about cmos doesn't make sense to me
    nothing happens when i turn the computer on at the moment
    there are no beeps, just a blank screen. mother boarc asrock k7s41gx. would i reset the bios before upgrading? i've changed bits about in pcs before but not processors.would it need more grease between it and the heat sink? thanks
    President:
  • 2,961 Answers
I think that the FSB needs to be set at 133 as this relates to your memory timing and im guessing your ram will be sdram, apologies if it's ddr, but you will find that you can up the cpu speed within the bios, in small increments. Don't forget the speed of athlon processors does not match the model number, the 2400 means it will be the equivelant of a pentium 2.4 GHZ, but it will probably show a GHZ rating of 2 or 2.2 Also try reseting the cmos by shorting a clrcmos2, clrcmos,clrrtc or putting the jumper from pins 1-2 to pins 2-3 then back again if it's a JBAT1 terminal, depending on your board.
Posted on Jun 13, 2007
  • andrew pester
    andrew pester Jun 14, 2007
    it maybe that the bios is required to be reset for the cpu upgrade, so resetting the bios may be required, the terminals i mentioned are in the motherboard, but vary with different makes.
    The memory timing will have to match the FSB, but if there is nothing happening, just check that the processor doesn't need to be powered by a seperate power lead from the power supply unit, as some do, instead of being powered by the ZIF socket alone.
    If you can get in the bios then the board is ok, so it's missing something when the cpu takes over, if you get one beep, then the memory is ok, a second beep reports the video is ok.
Looking for a compatible processor for this mobo
It is impossible to fry a motherboard by using the wrong processor, the board simply won't post. You can use a chart at the ECS website, your motherboard is a Socket A type. Looks like the fastest processor that they have tested is a Athlon XP 3000+.
Apr 04, 2009 | EliteGroup 741GX-M Motherboard
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
amd 3200 + anthlon ok with fsb 266 mhz soket a
Jan 10, 2008 | ASUS A7S333 Motherboard
K7VT2 with a AMD Duron 1.30 GHz CPU.
Depends on which AMD processor you would use. If Duron you could go to 1.8Ghz. If you use Athlon XP you could go to 3200+. Athlon MP 2.1Ghz and regular Athlon 1.4Ghz.
Nov 13, 2007 | Asrock K7VT2 Motherboard
Upgrade compaq
you can, go to www.tigerdirect.com.
ensure your purchase is compatible with the chipset in your pc
Nov 11, 2007 | Compaq Presario 1200,1600, Series CD...
Processor
hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
Jul 16, 2007 | Compaq Athlon XP 2000+ , 1.67 GHz...
Asrock K7S41GX Motherboard Logo
82 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
