CAN'T FIND A SKY REMOTE CONTROL CODE FOR A TWF TELEVISION
AS ABOVE
  • tez_ryan Jan 27, 2009
    SEEN THIS LIST BEFORE, BUT IT DOS'NT INCLUDE A CODE FOR A TWF TELEVISION, THANKS ANYWAY
  • Anonymous Apr 29, 2009
    code for twf tv on sky remote
  • 837 Answers
Sky remote codes for television model 42PF9631D/10
Hi
The correct code (or whether there is a code at all) depends on which version of the Sky remote you are using. The version number of the remote can be found on a sticker inside the battery compartment. If you have "RC1600/00" "Rev 4" or "Rev 6" on the sticker, then it's unlikely that it will work with your TV, but please read on as this isn't always true.
If you have a "Rev 8" remote then it's more likely to work with your TV, however, according to Sky, you will need to buy the new "Rev 9" Sky remote:
http://www.thedigiboxshop.com/sky-hd-remotes-sky-hd-remote.html
If buying one, be sure to check the button for the "Rev 9" version ( £0.85).
The actual code for your TV model is: 0718
I suggest you try the above code regardless of which version of Sky remote you have as Sky's information is not always accurate. You can also try these generic codes for Philips TVs:
0584, 0266, 0065, 0749, 1679, 0199, 0679
Again, try these with whichever version of the Sky remote you are using. There is a good chance that one of them will operate the volume and power functions on your TV. If none of the above codes work, then you will probably need to buy a Rev 9 remote.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Dec 17, 2010 | Televison & Video
Sky remote code for lg television model no.32pg6000 to programe remote controll on sky remote
Code is 1293 if you're using a Rev 8 remote control. You can check this on the sticker in the battery compartment.
If you are using an older Sky remote Rev 6, Rev 4 or plain old RC1600/00 then it's unlikely to work as these remotes aren't programmed to control your TV. You are welcome to try though ;)
Please post back if you need instructions on programming the remote.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | LG L3200AK Television
Need tv code for sky remote tv is an lg lcd
  • Turn your TV on.
    2. Press tv on your Skyremote control.
    3. Hold down select and the red button together for about two seconds, until the red light on the Skyremote control blinks twice.
    4. Press tv on your Skyremote control again.
    5. Key in the four digit code for your brand of TV. The light on the Skyremote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
    6. Press the standby button on your Skyremote control. If your TV switches off, press select. The light on the Skyremote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
    If at this point the LED on the Skyremote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
    At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
    8. Press tv on your Skyremote control.
    9. Hold down select and the green button together for about two seconds, until the red light on the Skyremote control blinks twice.
    10. Key in the number of the channel on your TV that you use for watching satellite TV.
    11. Press select on your Skyremote control. The red light blinks twice. The remote control setup process is complete.
LG Lucky Goldstar
20LCR1
SKY+ Rev 8
0206
ashley hawkins
26LC2R
SKY+ Rev 8
206
Peter
29FD6ALQ
Sky Rev 8
0206
Clive
32LB1DB
Sky Rev 8
0206
G Gibson
32 LC2D
SKY Rev 6
0206
Nils
32LX2R
SKY+ Rev 6 (?)
037
trevor
32LX2R
Sky Rev 8
0056,
0206
Ian
andy
32LZ2R
SKY Rev 4 or earlier
0037
GooseDog
37LB1D
Sky Rev 8
206
simon
37LC2DB
0056
g pepperrell
37LC2DB
Sky Rev 8
206
Adam Wilkinson
37LC2DB
SKY+ Rev 8
0206
Michael B
42LC2DB
Sky Rev 8
0056
Chris Lee
42PC1D/
536
mark baker
42PC1DVA
Sky Rev 8
536,0056
MALCOLM
42PX5D
SKY Rev 6
0065
ben booer
42PX5D
Sky Rev 8
1206
ANGIE
50PCID
SKY Rev 6
0065
terry
50PCIDA
0065
mr r
DI28Z12
584
Ted Warren
FLATRON
SKY+ Rev 6
0065
Justin Dean
RE44SZ21RD
SKY+ Rev 6
Sky+HD Rev 8
037
gavin court
RI 28CZ10RX
SKY Rev 6
742
Ray
RI32CZ10RX
SKY Rev 8
0742
Richard
RZ-15LA32
SKY Rev 6
065
ronnie fletcher
RZ-15LA70
SKY Rev 8
0206
MR B, BRY
RZ 20LA70
SKY Rev 8
206
stef w
RZ32L255
0063
DONOVAN
RZ32LZ55
Sky Rev 8
0206
0056
Dave R
bart simpson
RZ-37LZ55
SKY+ Rev 6
1206
Dan
Note: The LG codes that Sky have provided us to work with our newer television sets are; 0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318, 0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367. We also have some older codes; 206, 037, 060, 065, 080, 137, 191, 244, 245, 275, 318, 389, 391, 398, 405, 459, 502. The codes are stored in a database of the Sky remote. If the above codes don't work you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the new Sky remote which may have the updated codes. Best regards, LG Electronics.
If none of the above codes work try this:
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the standby button on the Sky Remote (The TV should go to standby)
5) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful.
Seems to be a handy way if you can't find the code for a TV.
It worked after about the 6th or 7th time hitting TV then Standby for me.
Jun 10, 2010 | Televison & Video
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
Had sky + h d installed engineer does not no code twf tv
perss interactive on sky remote move down to sky customer service press select move down to program your remote you will need the manufacture and model number of the tv they are found on back of the tv once you have them folow the on screen instructions
hope this helps
Nov 14, 2009 | Sanyo DP26746 26 in. LCD Television
Remote control code
Television Direct Codes for Sky remote:
Goldstar 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
Here are the codes for GoldStar which became LG. They might be the same.
Good luck,
Techjoel
May 09, 2009 | LG Televison & Video
Hyundai 32" tft lcd tv. model no.hlt 3270
I don't know if these codes will work but the Hyundai ones we use are code 1272 or 0662.
To put the code in:
Press TV
Press and hold Select & Red until the LED blinks twice
Put in the first code above
press Select
then try the volume buttons, if that doesn't work do exactly the same sequence but try the second code, if neither work let me know and I'll try and find another code for you
Jul 30, 2008 | Hyundai HPT-4250 Television
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Televison & Video Logo
333 people viewed this question
Top Televison & Video Experts
Electro Med Services...
