Question about HP LaserJet P2015dn Printer
HP 2015 laserjet will print text but not graphics
I am trying to print out our invoices which have our logo at the top. Normally they print out fine but when I try to print them now I only get a little black line.
  • 72 Answers
Reinstall the printer driver from hp website
Posted on Jan 16, 2009
HP LaserJet 2015 printer series - PCL XL ERROR is reported during printing
First Solution :
1. Disconnect the Power Cor from back of Printer ( while printer is has power )
2. Wait for 10 seconds
3. While holding Power Button, Connect the Power cord and release the power button
2nd Solution :
This issue can be fixed by enabling the following option in Printer Preferences . To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet 2015 PCL, and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Jun 18, 2010 | HP LaserJet P2015 Printer
White lines and "missing ink" on printing text & graphics
you have a defective or near empty toner cartridge. Try shaking it side to side
Jun 11, 2009 | HP LaserJet 1100 Printer
Laserjet 4 plus not able to print graphics
try the lj4 not plus or the lj5 these have always worked fine for me if problem still persisits do a printer test print from the menu button on the printer to make sure that the issue is not a printer formatter board
Regards Al "alstech"
Jun 11, 2009 | HP LaserJet 4 plus Printer
HP LaserJet 1022 changes the output order for checks, statements, invoices. Worked fine until 4-5 months ago (we switched over to a citrix server). Have tried reinstalling to citrix and local hard driver...
It sounds like a computer software issue. However to overcome the problem through the printer you can try this.
When the screen pop up comes up for printer selection, highlight the printer you will be using, then goto "Preferences". At the top tab click on "Advanced". Go to the bottom of the menu for "Layout Options" and change "Page Order". This should solve your problem, though you may have to change it back to print regularly printed materials.
May 18, 2009 | HP LaserJet 1022 Printer
Laserjet 5p leaves a thin white vertical line when printing
Either the drum and/or developer is scratched or has a line on it ..
Dec 26, 2008 | HP LaserJet 5p Printer
HP2100 laserjet won't print inserted pix in Word 2007 doc
I ended up fixing this problem myself.
I needed to set the printing resolution in the HP printing dialog box to 1200 x 1200 dpi as the HP2100 can print at this resolution.
Select: Print/Properties/Advanced/Graphics. Then set the printquality to 1200 x 1200 dpi.
Rod Salter
Dec 15, 2008 | HP LaserJet 2100 Printer
Stops Printing Entire Page After Around 50 sheets
First, check the text in your records for odd characters. It is sometimes possible in data entry to hit a ctrl-"letter" combination that embeds printer codes in your text and these are invisible in many cases to the application. The easiest way is to break up your print job to sections of records and see if a particular record consistently causes an error.
If your sure however that the printer is the problem...
Then I would check the RAM. The printer has 128MB upgradable to 512MB. Normally you can pull the ram and run jobs on the internal memory, but in this case you would need to swap it out.
Jun 05, 2008 | Ricoh Aficio CL3500N Laser Printer
Regarding printing of envelopes.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00602236&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=439428&productBigSeriesOid=14924&spid=439320&pname=HP+LaserJet+1020+Printer&opname=HP+LaserJet+1020+Printer&pname_desc=HP+LaserJet+1020+Printer&st=1&ptype=consumer&stype=pn&qry=printer+doesnt+print+the+first+time&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+1020+Printer&cqry=&uqry=
Oct 20, 2007 | HP LaserJet 1020 Printer
Won's print pdf files
Trouble with the HP Laserjet printed output may be solved by using the following settings (or similarly named ones): "Use raster Graphics" (instead of "Use vector graphics"). This may fix the problem of "reversed" text (white on black background) not printing, as well as other problems. "Download TrueType Fonts as bitmap soft fonts" (select "bitmap" instead of "outline" or "graphics"). This may remove the overlapping of text on the printed document. "Graphics dithering" select "coarse" or "fine" (instead of "none"). This selection may improve the quality of images contained in the document. You can find all these settings in your printer properties. Go to File, Print, click Preferences, in Printing Preferences, click one by one all the top options, and change one of the top solutions, one at the time, checking your printing output. Always check if you have the latest version of Adobe Reader Program. If not download the latest version from Adobe, it's free. Is this the first time that you have the problem? or with the same printer (HP 4si), did you were able to print PDF files in the past?
Sep 10, 2007 | HP LaserJet 4si Printer
HP LaserJet P2015dn Printer Logo
228 people viewed this question
Seeker5211
Seeker5211
