Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Wtw6200sw1 f-68 fault code
Unit stops and f-1 intermittenly right after lid lock also does this at 20 min. left or at final drain spin
  • Anonymous Feb 10, 2009
    Same Problem, called Whirlpool, they say no recall on this problem, although a friend has an almost identical machine and it is on recall. Whirlpool offered 15% discount to purchase new machine (2 years old), told them to shove it and take my washer which has already had a board replaced, and my whirlpool dishwasher which has had 4 boards replace. What a peice of **** company!
SOURCE: Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Posted on May 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: Washer won't agitate
I saw this happen once and you know what it was? A loose connection!. I pushed in the timer's molex block and it worked! It musta vibrated out the socket somehow. You must flip up the console to access the controls.
Posted on Feb 17, 2009
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Posted on Jun 02, 2009
  • 82 Answers
SOURCE: washing machine does not spin
check the brushes on the moter
Posted on Jun 28, 2009
Online-Tech
  • 51 Answers
SOURCE: whirlpool awo 3751/5 will not spin
There is a locking coupler on the Whirlpool washing machines that locks when it kicks into spinning cycle. I am guessing here, but if you try and run it without any clothes in it, it will probably spin. It will be slow starting, but it will probably spin.
The coupler is located down by the motor and is three pieces. They made it out of plastic, and while it typically holds up very well, they do break. I will try to look up the part # you need to fix it. (assuming this is your problem)
Thank you for contacting www.Fixya.com
Posted on Jul 29, 2009
Won't go into final spin and lid lock light flashes
Will try and point you in the right direction you probably have one of the F7 codes which relate to motor speed, since the lid is locked you have to get the entire top up to do this on the back of the machine there is a screw on each side same level remove slide top bout 1/2" forward lift on the front panel infront of basket to the left should be a plastic packet with the service manual it will tell you how to place the machine in diagnostic and explain the error code and possible causes
Sep 05, 2014 | Whirlpool WTW4800BQ White 27" Washer Top...
Why does my washer stop spinning on final spin cycle and show code of UL even when there is nothing in washer?
you either have a broken tub support spring or, the uneven load sensor is reporting because of a bad controller unit.
Aug 12, 2014 | Whirlpool Washing Machines
All the lights come on but the CAE2793BQ will not runa cycle
We had the same problem. we bought a new control board for a local part shop for $335 (could buy online for $150) The part came with instructions how to reset the LEDs which indicate a failure has happened. This sheet IS NOT included with your manual when you buy the washer. The sheet reads that you need to recalibrate the washer when installing, or after moving unit to a different outlet. How bad is whirlpool not to include this in manual?
to reset: put knob in 12 o'clock position, wait 3-4 sec then; turn knob with the following combination, pausing shortly between clicks (within 6 sec).
turn left 1 click, right 1 click, right 1 click, left 1 click, right 1 click.
success activation of diagnostic mode will be that all LEDs (except lid lock) flashing on/off half sec intervals. Start calibration;
Toggle the cycle knob until the RINSE led is lit;
do not interrupt power, lid must be down, basket empty. press START to begin calibration (3-5 mins).
Lid will unlock and go into stand by mode. If this didnt work then the original fault still exist. It should flash a fault code, but i dont have that sheet. Whirlpool said it should of came with your washer.
hope this helps
Feb 26, 2014 | Whirlpool Heavy-Duty Series Energy Plus...
Maytag centennial washer
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
Nov 03, 2013 | Washing Machines
LD ERROR CODE AND WONT DRAIN LID WILL LOCK
try any button sequences yet . try holding start button and a cycle button hold both down to reset
Apr 01, 2013 | Whirlpool Cabrio WTW6800W Washer
Whirlpool cabrio wtw6500ww1 stopped working when it needed to spin n drain?
get a putty knife and between the top and cabinet about 2 inches in on the left and right shove the putty knife in to depress pins (this can be frustrating) once you can lift up the whole top you will find a tech sheet in the inside of cabinet left . also you will need to do this to replace lid switch. run through diagnostics to view all errors . there will be a list of error codes in this tech sheet with troubleshooting ideas.
Feb 17, 2013 | Washing Machines
How do i get codes for a whirlpool cabrio wtw5500xw0 washer with no display?
Error codes for WTW5550XW whirlpool cabrio
It would appear that no one read your original post, I believe you asked: HOW DO IT GET THE ERROR CODE. I have the same machine and had the same problem. The method is descibed in the service manual available at servicemanuals.net for about $17. It also has a decent wiring diagram and how to generally do anything the local service guy could do well worth the money for a download you can have in your hands in minutes.
Back to your question.1) turn the washer off (the power button) all the indicator lights should be off.
(now think of your old gym locker combination lock, cause it will be a little like this)
2a) rotate the center selector knob CCW (counter clockwise a few clicks), this seems to get the machines attention
2b) immediately rotate 1 click CW clockwise
2c) immediately rotate 1 click CW (again)
2d) immediately rotate 1 click CW (again)
2e) immediately rotate 1 click CCW
2f) immediately rotate 1 click CW (again)
visually it would look like this <---,->,->,->,<-,->
now just the led's below the indicator should be blinking off and on on about 1 second intervals
you may need to try a few times to get the timing just right, you aren't spining through the clicks, just about enough time to say "left-left-left-right one,right-two,right three,left one, right one
with all the led's in a row blinking you are ready to go into code mode.
(sensing soak wash rinse spin done) (mine doesn't have soak BTW)
3) rotate the selector knob a few clicks until only the "done" led is lit
4) press start
5) the led's should blink again
which leds blink tells you alternately the fault# and error# when the "sensing" led is blinking, the other leds are indicating the fault number, when it is not on, the indicate the error# the fault# is the type of problem, and the error# indicates where the problem was detected.
6) a partial listing using the fault #, I will indicate the led as follows: Sensing/Wash/Rinse/Spin/Done
S/W/R/S/D this would be all these leds lit
s/w/r/s/d this would be all these leds off
the F# codes to the right is what you would see if you had the numeric display on the console (not all models)
Here goes:
Over suds condition: S/w/r/s/d F0
High water temp rinse cycle: S/w/r/s/d F0
Off balance load: S/w/r/s/d F0
Main control fault: S/w/r/s/D F1
Motor control fault: S/w/r/s/D F1
Stuck key: S/w/r/S/d F2
Mismatch of main control UI: S/w/r/S/d F2
Pressure sensor fault: S/w/r/S/D F3
Inlet water temp fault: S/w/r/S/D F3
Lid switch fault: S/w/R/s/D F5
Lid lock fault: S/w/R/s/D F5
Lid unlock fault: S/w/R/s/D F5
Lid not opened between cycles: S/w/R/s/D F5
Basket speed sensor fault: S/w/R/S/D F7
Shifter fault: S/w/R/S/D F7
Motor fault: S/w/R/S/D F7
Motor unable to reach target rpm:S/w/R/S/D F7
No fill long fill: S/W/r/s/d F8
Overflow: S/W/r/s/d F8
Hot cold reversed: S/W/r/s/d F8
Long drain: S/W/r/s/D F9
yes several of these had identical blinking light combinations, but it is good start.
Apr 21, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
My washer starts and stops a few seconds later with a FL code
Hello donaldwoulla,
I’m an owner of a FAV6800AWW not a GURU, this forum automated rating system is way too generous, I will try to help. Do you feel OK to try some troubleshooting? The following troubleshooting assumes you want try a possible DIY fix.
“FL” code is Failed to lock, we will try a few troubleshooting steps. The following test will be done by selecting the Spin Only cycle. First test will be done in service mode.
1. This is from SM; Press Enviro Plus and Spin Only keys for 3 seconds to activate Service Mode. Access Board Output Test by pressing the Delicates key. Display shows “ot” and the lid locks should actuate locking the lid. Does this happen, do you take the “FL” fail code in this process? Hit OFF button to cancel this test.
2. I want to make sure you signal an “OP” alarm to the display. Can you select Spin Only cycle with the lid open press start. Do you signal the “OP” alarm, lid open to the display? If it does close the lid and the “OP” alarm should clear, does it? I’m checking that the lid magnet is in place and the signaling connections are working thru the left lid lock back to the control board.
3. With spin only cycle selected and the lid closed press the Start Button do both lid locks try to close and lock the lid? From your initial post I believe you throw a “FL” to the display very quickly, that is the left and right lid locks do not actuate several times before the control board displays the “FL” fail code. Is that correct?
4. This step requires you to raise the top off the washer you will need to the move the washer out several inches and you should have a helper available to hold the lid up for you. Unplug the washer from the 120VAC outlet. Use this info and the FAV6800A/9800A Service Manual to assist you. To raise the top of the machine, insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point. We are going to reseat the Left Lid Lock plug a couple of times into the Left Lid Lock. We are checking to see if there might be some corrosion on the plug contacts. Take a look at page 34 of the SM. Top right of the page Lid Lock/Reed Switch Removal where the persons thumb is. This is the plug we want to remove and reseat a few times. It may be difficult to do remove so be careful. Mine was very difficult to remove the first time. This lid lock is near the bleach dispenser and other owners have had corrosion issues with this left lock causing issues. After doing this and you have reseated the plug into the left lid lock a few times power up the washer and give it a try.
Just to let you know don’t worry about the right lid lock, it’s signaling and control functions are in parallel with the left lid lock. I’ve had mine disconnected since mid Dec. The left lid lock is the important lid lock. It has the dual functions of signaling the control board that the lid is open/closed by the magnetic reed relay in that lid lock and the lid is locked by contact closure back to the control board in that lid lock. If this doesn’t help resolve the issue we will try removing the left lid lock to inspect if you feel OK to continue. Good luck. Rich
Mar 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
110.26842692 series 80, tries to spin while pumping out.
correctm the lid will need to be closed to spin/drain water, if your experiencing an issue that it intermittenly stops during thiscycle, possible that the lid switch is GOING bad, and not always making contact.
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
498 people viewed this question
Dan Webster
Dan Webster
Sal De
