Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Popping noise from speakers/ No sound on Vizio P50HDTV10A
There is no sound coming from the speakers. Just a consistent popping sound. Tried various connections to no avail. Surround sound works fine so I know it is not the sattelite box.
  • 4 more comments
  • Anonymous Jan 31, 2009
    Have a 32 inch visio plasma. After first turning it on it has a continuous popping sound and no other audio. Sometimes the popping stops and the audio returns. I'm thinking this aint right.
  • hoovers Feb 05, 2009
    Recently starting hearing a popping/cracking noise on our 32" Visio.  We can still hear the TV audio, but popping noise is becoming more frequent.
  • PrettyBrowns Mar 01, 2009
    OMG!! my 47 inch vizio also makes snapping, popping, cracking noises..when its turned off and on!! my warranty is up now....and i am a bit worried. glad to know its not just my tv..
  • taralee0616 Mar 02, 2009
    popping sound from surround sound kit....help!
  • ronnawilson Apr 23, 2009
    Suddenly a popping coming from speakers.
  • wgreen May 05, 2009
    I have no sound from the Vizio P50HDTV10A internal speakers so I ran audio out from the Vizio to my amp which works fine. You need to change the audio setup in the Vizio menu to send the sound to the audio out jacks. Anytime power is lost to the TV, the menu setup must be done again. It's a bum way to get the sound but it works okay.
    Now I can't get it to switch from TV into the DTV mode. I see the DTV letters on the tv but no vido/audio signal nor can I access the DTV menu. In the past, I had to turn the tv on and off to switch, but now it doen't work. Any help will be appreciated.
  • 5 Answers
SOURCE: Loud Pop Vizio P50HDTV10A 50 in.
change the Z board
Posted on Sep 05, 2008
WeListen2You
  • 538 Answers
sounds like the power supply board..could be the system board, but sounds more like the power supply board..this unit still under warranty?
Posted on Oct 20, 2008
Axle80
  • 73 Answers
SOURCE: 50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Posted on Mar 23, 2009
  • 8457 Answers
SOURCE: Vizio P50HDTV10A TV went pop now has a black picture
Don't know which boards Z or Y have dead capacitors pop open,take ur tv aparts check boards that have pop opens parts or burn marks on them.Replaced that board will solved ur problems.Tries Shopjimmy.com,Ebay.com to buy refurbish boards for the replacement.
Posted on Mar 22, 2010
  • 8457 Answers
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Posted on Apr 07, 2010
What amplifier do i need to connect 4 speakers to my vizio P50HDTV10A TV
Check the back of your set there are 2 Audio RCA Jacks, You can't do it with an amplifier alone because that won't split the channels to 4. You have to go to a surround sound receiver.
Jul 14, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Oct 20, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
P50 sound ok picture went dark but not out all the way. Made a loud noise when it happened
did you ever get a answer?
i also have a p50hdtv with a black flickering screen
but no pop and sound is still working.
May 10, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Mar 22, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
The l/s speaker has a terrible rattle when sound has a little bass..either something is loose or driver is making the noise.Can you remove the grille without taking the tv off the wall?
Hi, Sorry no you have to take the back off. And there are several screws. You can buy replacement speakers off E-bay. For about $10-20. Cheeper than part stores like Shop Jimmy or Encompass. Also note that the speakers in the tv are small, 2.75" in most of the Vizio sets. The 32" have 2" speakers.
So not realy made for bass,or to play loud.
Oct 31, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Short crackle sound emits from speaker during scene changes
Actually, it is a failing component. Quick scene changes often place demands on the power supply. I would guess that the noise is more prevelant when the scenes change from darker ones to lighter ones. Since this set is so new, request a warranty exchange. This set needs to be serviced. Return it to the place of purchase and ask for a replacement. Usually if the set is less than 30 days old, they just exchange it for you.
Dan
Oct 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio vp50HDTV10A Plasma Vidio and Audio on and off
Odd problem for this model.
If:
* you are certain the popping is coming from the speakers and
* the video and audio come back on after going out (without reset) then
the issue will be with the main board and will need to be replaced.
Call Vizio customer service, they extend warranties sometimes.
Dec 21, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio 50
The popping noise is coming out from the speakers , because some electronic component is shorted like this Z board , it is important to you to know that you can spend less money fixing this one than buying a new one . be ready to spend between $300 to $700.00 in parts. if you choose to not fix
you always can recover your money . returning parts not used to the vendor and or selling your tv as it is.
Your rating to my answer is highly appreciate
thanks
Jun 29, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
395 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
