Question about Honeywell HCM-300T Humidifier
Honeywell HCM-305T Spits droplets rather than creating a mist.
My brand-new Honeywell ultraviolet cool mist humidifier is not creating a fine mist but rather sits out droplets of water, soaking the floor around it. I tried setting the humidistat on the 2nd lowest setting but the same thing happened. There is a sound that it makes, like sleet hitting a gutter, as the water spits out. The first night of use it worked fine. I was afraid I damaged the unit when I dropped the empty tank during filling, but there are no cracks nor any leaks when filled. The tank and filter are situated correctly. What would cause this problem? I can't use it if the floor gets soaked everytime I do.
  • 4 Answers
This has nothing to do with any sort of nozzle as there isn't one on this device. As Skybum said, the "moat" overflows into the fan and then gets spit out as the fan turns. The device is wonderful at saturating floors but unfortunately not the air!
This is also not a consistent event. The humidifier will work for some time and then all of a sudden I wake up with a soaking wet floor.
Posted on Feb 16, 2010
Mine does the same thing!! I don't have a "misting nozzle" but rather a "moat" that the filter element is sitting in. This moat fills up with too much water, in turn, siphoning it out and down onto the fan... which then disperses it all over the floor.
It's like a carburetor running waaay too rich!! The tolerance of the water level is too tight for the water to not siphon out into the fan.... I've torn it apart, cleaned it, read the directions (again) and it still does this after 3 - 4 minutes on high. It'll be boxed up and returned to Costco today.
Posted on Jan 31, 2009
    Novelist:
  • 88 Answers
Thanks for your question,
Sounds to me like you have something partially cloging the misting nozzle, if you can take the nozzle off, and check it I would bet there is something that got in there, if you cant, it might be better to just return the Humidifier where purchased for an exchange, if you can get the nozzle off, if you have a can of compressed air like they sell for dusting off computers, I would use a very short burst of that in the nozzle, and in the feed line, thanks again for your question, let me know how it works out,
mr.grzz
Posted on Jan 21, 2009
  • balabask Dec 03, 2010
    Hi All,
    I have been using this unit for more than 5 years now non stop, we stop when we go for vacation. The unit still works good but has a leak issue of late. This is attributed to the usage of water treatment solutions and anti-bacterial solutions that I used. Though the filter life is enhanced, the washer "WHITE" coloured band in the lid is loose and does not help arrest the water anymore. I believe it is time for me to buy one more of the same kind!. I am happy with the product.
Lights on but no fan, no mist
"Take the humidistat out of the humidifier and look for the 3 slits below the restart button, take a hair dryer and send some warm air into those slits for 5 minutes. That usually recalibrates the humidifier."
Feb 06, 2014 | Honeywell QuietCare HCM-6009 Humidifier
Our HCM-640bw Honeywell humidifier will leak water onto the floor. If I fill the tank and let it sit without turning it on, no leaking. When it runs for about two hours it leaks bad. Any ideas on how to...
Found a hairline crack in the water canister. Had to locate by filling the canister and waiting for a couple of minutes for water droplets to form outside the canister. This ever so slight crack allowed air to enter the chamber and made changes to water dispensing rate which overfilled the resevoir over time ( hours). The cracks were not visible under 10X magnification without the water droplets.
Jan 18, 2010 | Honeywell QuietCare HCM-630 Humidifier
Tank is broken on Honeywell HCM-560 humidifier.
you type in on the internet. www.appliancefactory.com
in the search bar type in your model number. it might take a minute to load but you will have 3 pictures that come up. click on any of them and scroll down alittle until you see water tanks. you can order them there.. or if youdon't want to go that route you can always try local hardware stores to see if they have it as well.
Mar 30, 2009 | Honeywell Cool Moisture HCM-560 Humidifier...
Fan works, but no mist and water isn't going away
Turn on furnace and urn up humidistst to call for it. Tube from solenid to the filter should have water running if water is up to the valve and solinoid is opening . It should be warm to your touch., Using an ohm meter you can sheck the coil it shuold have continuity.
Mar 11, 2009 | Honeywell QuietCare HCM-630 Humidifier
Humidistat problems
The ability of the humidifier to maintain a given moisture content in the air is far more difficult than a heat or cooling unit to heat or cool the air.
Moisture vapor has far more energy to seek dryer air, than tempered air. So the moisture seeks and finds dryer air quickly, whether it be through stair and door ways, or through cracks and seams in walls and doors/windows, or through non vapor barrier surfaces.
The only way the unit would be able to achieve a humidity level as stated, is for the unit to be placed in a vapor-tite room that has a minimal of leakage.
You could put more humidifiers in the space, or more and larger humidifiers in the space, to try and overcome the vapor moving to other areas of the space. But unless you have a fairly vaportite space, it is unlikely the unit is under capacity, and the only way to test what capacity is needed is to take humidity measurements.
Reply back with any questions you may have.
Feb 03, 2009 | Honeywell HCM-300T Humidifier
Where is on/off switch HCM-305T-CST
There is a 0 setting on the fan speed setting knob ...
Dec 20, 2008 | Honeywell : Cool Moisture Humidifier...
Honeywell HCM-300T Humidifier Logo
818 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
