Question about Sampo PME-42V3 42 in. Plasma Television
I need a power supply board for a Sampo TV Model PME 42V3
Can you please help me find this power supply board?
  • 1,031 Answers
You can ge the power spply board here http://www.discount-merchant.com/SearchResults.asp?Search=+PME-42V3&Search.x=14&Search.y=15 hope this helps thanks and Godbless
Posted on Jan 14, 2009
    Scholar:
  • 160 Answers
Http://www.shopjimmy.com/TVs/Sampo/Sampo-TV-Parts.html
you can get the power supply board at the given link.
thanks.
  • 837 Answers
  • 2,336 Answers
Click here to find the power supply. You could also contact them with the model number of your plasma.
  • Sampo Master
  • 19,396 Answers
Buy from here .
If the part is not in list, then give them a call.
    Sergeant:
  • 221 Answers
You can the required parts at www.partstore.com just select the exact model number and exact brand and the required part will get listed.just select and order one for you.
Can i just hook up a dvd home entertainment center.i need instruction on how to do it
Hi, I am sure we can help, but please provide the system number and make so we can check for wiring schematic.
Dec 03, 2010 | Sampo PME-42V3 42 in. Plasma Television
Relay clicks then shuts off - no picture/ no osd
No picture
  1. Power cord disconnected.
  2. Power not switched on.
  3. Improperly connected signal cable.
  4. Monitor in power save mode.
  1. Connect power cord.
  2. Turn the power switch on.
  3. Connect the signal properly.
  4. Press any key on computer.
Mar 05, 2008 | Sampo PME-42V3 42 in. Plasma Television
Just clicks when powered on
Check for the power supply. Need to be replace.
Nov 01, 2010 | Sampo PME-42V3 42 in. Plasma Television
Please tell me about power supply problem and solving diegrame
The power supply for HDTV is the board where the AC plug goes into. It is a very sensitive circuitry that can be easily damaged. Under normal circumstance it is very reliable. This is how they work basically. The AC current is rectified (converted into DC). Then filtered by means of large capacitors. The DC Voltage ( about 180 DC volts from 120 AC) is supplied to power transistors (usually FET or field effect transistor). The Transistor are switched at high frequency( usually over 100KHZ or 100,000 times per second) Which drives the transformers to step down the voltage. When the TV is off there is a standby voltage which is on at all times, and it is typically 5V. This standby voltage is the first thing a technician check for when troubleshooting power supply problem. When the TV is turned on everything in the power supply comes to life supplying power to every circuit boards which are of diffrent voltages such 12V, 24V etc. HDTV power supplies are very complicated using the latest technology employing power saving chips that minimize power usage on standby mode. Explaining the it in great detail would require many pages but this is just the basic.
Jun 26, 2010 | Sampo PME-42V3 42 in. Plasma Television
Need universal remote control code for maxent 42" plasma tv?
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
246
730
746
Becki Barned
DISH Network Customer Service
May 17, 2010 | Sampo PME-42V3 42 in. Plasma Television
Sampo PME-42S6 doesn't turn on
Same problem red alarm led comes on you need the power supply unit it's $139.00 you can fix it your self. And gateway dont have to parts i have a phone #
Dec 13, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
I have good Power supply board for your Sampo 42S4 tv,
do you know if your power supply board will work for the Sampo 42S6?
If so, I am interested.
RyanHoffmeyer@hotmail.com
Sep 13, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Got a 42 sampo plasma tc, no picture
Howzit Brother.
I had the same problem, but managed to repair it myself! There is no need to purchase a new
Power Supply! You can service the faulty PCB yourself, or give it to a Tehnician to service for you.
If you want to try service to yourself, here is how,
On the PCB marked QPWB11326-1B-4 you will need to do the following<
Replace the following Capacitor's, CS704(Most important one), CS705, CS706, CS707, CS708, CS713, CS715.
Replace the TOP210PFI IC marked ICS02
Replace the PC123 OPTO marked ICS03
Replace the TL431 Shunt Regulator marked ICS04
This solution should work! email me on engineering@elektroniktechnisch.co.za if you have any other requests!
Gavin Burger.
Jun 12, 2007 | Sampo PME-42V3 42 in. Plasma Television
Sampo PME-42V3 42 in. Plasma Television Logo
159 people viewed this question
Top Sampo Televison & Video Experts
Lyle Siemens
Lyle Siemens
Starnley Johnwells
Starnley Johnwells
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
