Question about Indesit W 123 Front Load Washer
Indesit W102 drum stopped turning & has error lights flashing
My 4 year old machine starts the cycle as usual, fills with water, does one spin of the drum and then the motor sounds but the drum stops spinning and lights flash continously and quickly on the machine. Not sure if it's relevant but the lights that flash are the on/off, stain removal and extra rinse buttons.
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
Posted on Jan 20, 2008
jaylex
  • 417 Answers
SOURCE: Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Posted on Feb 10, 2008
SOURCE: Indesit 1000 cycle starts but then lights flash
Check the filter which is under the white panel at the front of the machine(the filter is in the lower right hand corner). Unscrew the filter and remove it. Mine was blocked with loads of grease/limescale. I cleared it out and the machine is as good as new again. I cleared the system with half a packet of soda crystals put into the main drum (on its own without any washing in!) and did a wash at 90degrees. Its as good as new now. Good luck. CK
Posted on Jun 13, 2008
ngfam1
  • 639 Answers
SOURCE: got an indesit wi 133
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
beltronic205
  • 1474 Answers
SOURCE: I have an Indesit WIDL 126 washer/dryer. When you
Check delay swith has not been operated also try resetting prog.. handbook shows you this,
Posted on Sep 28, 2009
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
My Indesit Moon 1400 has stopped working. Shortly after the cycle starts the blue LED lights at start and 40 deg flash rapidly. Washing inside machine is soaking wet but has neither washed nor spinned. ANy...
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Jan 30, 2010 | Indesit W 123 Front Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine will not drain and carry on with full cycle
Same problem - changed module with no result. Looks like the water temperature thermistor...
Jun 12, 2008 | Washing Machines
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit w123 washing machine
Suggestion: The pipe behind your machine has to have a certain height (the machine drain pipe); it does not go directly into the drain at floor level. Check this out.
May 22, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
274 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
