Question about Polaroid T730 Digital Camera
Downloading pictures from Polaroid t831 camera
When I plug my camera (Polaroid t831) into USB cord (with it being plugged into the computer) and turn on the camera, I do not get a blue screen with options, to select "PC" (I did the very 1st time but haven't since then). How do I download pictures?
  • cox_family Jan 15, 2009
    Thanks for your suggestion.
    The computer is not reconizing the USB at all. It does recognize other things (flash drive & another camera) when plugged into that port though. I'm stumped.
  • lovetoflyguy Mar 06, 2009
    when i plug my t831 into the USB port, my computer doesn't recognize the device. I tried some of the devmgmt.msc stuff, but with no results. I heard something about downloading a driver so my computer can handle this. and when the device is plugged into the computer and I use the device itself, the computer restarts.
  • 75 Answers
Try this option, if it does not work, let me know and I will suggest something else!
Plug the camera in along with the usb into the computer and if nothing pops up, go to start, run and browse for your camera. It should show up there.
Posted on Jan 14, 2009
  • Mandee Jan 15, 2009
    go to My Computer, Right Click on it and Select Manage, go to Device
    Manager, Scroll down, if there are any hardware with yellow question
    marks you must update the drivers. If that is not the case, it must be
    a wiring issue.
    Method 1: Initiate recognition of the USB device by using Device Manager
    loadTOCNode(2, 'workaround');
    To initiate recognition of the USB device by using Device Manager, follow these steps:
    1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
    2. Click to select your computer as the location for the scan.
    3. On the Action menu, click Scan for hardware changes.
      Windows XP recognizes the new device.
    4. Close the Device Manager window.
    If this method resolves the issue, you are finished.
    If not...try
    Method 2: Disable power management of the USB hub
    Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
    Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:
    2. Expand Universal Serial Bus controllers.
    3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
    4. Click the Power Management tab.
    5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
    6. Repeat steps 3 through 6 for each USB Root Hub in the list.
    7. On the Action menu, click Scan for hardware changes.
    8. Close the Device Manager window.
Where do i buy a usb cable,for downloading pictures?polaroid t831 digital camera,are they available at wal-mart,radio shack,......where?
Consider NOT using a USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Even if you have to buy a card reader, it won't be any more expensive than a USB cable.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 27, 2010 | Polaroid T831 Digital Camera
I am looking for a usb cord to plug into my computer and download my pics. where can i order one?
You can't order for just usb cord on net because it comes alongwith charger and battery. The best way to buy it would be go to your nearest computer shop take the camera alongwith you and ask them for the usb cord. They will check the connector type and will provide you the cord. Don't forget to check the serviceability before leaving the shop.
Sep 17, 2010 | Polaroid T831 Digital Camera
Plug in polaroid t831 to pc and pc doesn't recognise that it is there
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
May 20, 2010 | Polaroid T831 Digital Camera
I need to download my Polaroid t831 driver
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Oct 29, 2009 | Polaroid T831 Digital Camera
How do I charge my camera?
go to ebay.com search Polariod t831 , it should be a cord with a little silver box at the end you slip the battery into the little box,but be careful make sure it is an A/C cord or you might be getting a car charger, the light will be red at first and when it turns green it will be charged. The usb cable is to put the pictures on your computer. Hope this helps you..
Sep 18, 2009 | Polaroid T831 Digital Camera
I am needing help downloading my pictures on to a website for a picture book
May 27, 2009 | Polaroid T831 Digital Camera
Can't upload pictures. restarts computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Picasa or any other photo cataloging program.
Mar 02, 2009 | Polaroid T831 Digital Camera
Polaroid t831 Blue Screen of Death when connected to PC
Jan 01, 2009 | Polaroid T831 Digital Camera
Polaroid t831 makes laptop blue screen!
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Dec 20, 2008 | Polaroid T831 Digital Camera
Downloading pictures to my computer
I don't use software or anything like that. Here is what I do:
1- Plug camera into USB cord (with it being plugged into your computer)
2- Turn on your camera, a blue screen will appear with options, select "PC"
3- Open your "My Computer" folder, you should now see a new drive, I have 2 hard drives so my camera is usually under "H://"
4- Select your picture(s) and drag and drop them into a folder or wherever it is you wish to store your pics. It will not remove them from your camera or memory card, it will simply copy them.
5- Power off your camera and remove the USB cord.
Simple as that! :) Again, that is just how I do it! I use Ulead PhotoImpact to edit my pics and such. Hope that helps!
Oct 08, 2008 | Polaroid T730 Digital Camera
Polaroid T730 Digital Camera Logo
333 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
