Question about Microsoft Windows XP Professional
Windows sp3 problems
Now i have installed sp3 for windows xp home edition at startup i'm asked which one i want to boot from 1 works and the other one does not can i get rid of the bootup that does not work thanks
    Scholar:
  • 96 Answers
If you're booting into a particular operating system which has another partition
optionally boot into:
When your system is fully loaded you click START.....RUN.....then type msconfig
and click OK. Click BOOT.INI and under "operating systems" view the order they
appear in and if the one you want to load on boot is listed second......highlight the
first one and click "move down". Next reboot the machine to view the change you've
made. Conceptual View
If you would like to delete a boot partition you'll need to right click MY COMPUTER
.....then click PROPERTIES in order to view System Properties. Click the ADVANCED
tab then under STARTUP AND RECOVERY click SETTINGS. This window will open:
Click the EDIT button and the boot configuration window will open in NotePad.
Highlight the partition you would like removed and press delete. Be very sure
to choose the correct partition because you can lose all of your data if incorrect.
When you reboot you will notice the deleted partition is no longer listed.
Nate P.
Posted on Jan 15, 2009
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Tip
Mamimum RAM for User @ 3GB using boot.ini switch on 4GB Physical RAM
The DOS will always take a percentage of the physical RAM on the motherboard leaving the rest for the User. By default the Windows Operating System will use 50% of the physical RAM installed on the motherboard leaving the user the remaining 50% this can be changed using a switch in the boot.ini file
The /3GB was originally meant to be used in systems that have 3GB or more of RAM something that is no longer quite as rare as it used to be Windows XP SP3 will support upto 4GB although on a 32bit (x86) version of Windows will acually see 3.25gb that is the limitation.
However, even if you don't have 3 GB or more of memory, you can still use the /3GB switch. the switch can have any value between 2048 (2 GB) and 3072 (3 GB) megabytes. It needs to be expressed in decimal notation.
The /3GB switch applies to 32-bit systems only (x86).
Example with Windows XP SP3 Home Edition with the recovery console installed this gives you the option of default 50-50% split or the 3GB switch 75-25% split.
The /noexecute parameter enables, disables, and configures Data Execution Prevention (DEP), a set of hardware and software technologies designed to prevent harmful code from running in protected memory locations using the optin switch enables DEP only for operating system components, including the Windows kernel and drivers. Administrators can enable DEP on selected executable files by using the Application Compatibility Toolkit (ACT).
The /burnmemory parameter specifies the amount of memory, in megabytes, that Windows cannot use in this example, /burnmemory=128 will reduce the physical RAM memory that is available to Windows by 128 MB.
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition 3GB Switch" /noexecute=optin /3GB /fastdetect
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition " /noexecute=optin /burnmemory=128 /fastdetect
C:CMDCONSBOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
Check out the noexecute and the 3GB switch plus all available boot.ini switches HERE
I suggest that you use AnalogX MaxMem it is a realtime physical memory management program that automatically ensures that you always have as much physical memory available as possible used with the 3GB switch you should never have memory issues ever again.
on Mar 14, 2010 | Microsoft Windows XP Home Edition for PC
Windows xp cd with sp3 installation
In BIOS change the boot order such that CD/DVD comes first. You will also need to make sure your hard drive runs in IDE mode since Windows XP doesn't support sata drives by default. FYI XP is going end of life early 2014.
May 20, 2013 | Microsoft Windows XP Home Edition
My windows xp startup disk with the os an drivers is no good microsoft says i need contack manufactures copy do have one
You should not have contact the manufacturer (microsoft)
one of these will help you
SP3 is the third and final service pack released for Microsoft Windows XP, and it eliminates many of the security holes that previously affected XP. While Microsoft recommends that users download SP3 using Windows Update, some users are unable to do so. However, it's easy to create a Windows XP SP3 installation CD; it requires only that you download the pack from the website and burn it to a CD-R/DVD-R using an ISO burner program.
Download the SP3 installation ISO by visiting the first link listed in the "Resources" section of this article. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en XP PRO SP3 ISO Download the iso also download the imageburn http://www.imgburn.com/
http://windows-xp-pro-startup-disk.soft32.com/ http://support.microsoft.com/kb/322389 http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid windows xp pro start up disc
post a reply if you need more help with this
Mar 12, 2013 | Compaq Presario sr1403wm AMD Sempron 3000+...
Recovering from malware attack
See the linked document on how to perform a repair install of Windows XP if you have not already done this.
Can you boot into Safe Mode or do you get the same hang issue when trying this?
As you can attach the problem XP boot drive as a secondary drive in another computer, I would recommend that you either backup all the user documents and data from that slave drive or that you make a backup image of the slave drive using any of the available backup tools such as Easeus Todo Backup or Paragon free tools
Dec 31, 2011 | Microsoft Windows XP Home Edition English...
Downloaded Windows XP Update SP 3. Now system
When you installed SP3 it was also placed into Add/Remove programs, (In control panel). Boot the system and enter safe mode. Uninstall SP3.
See also Microsofts instructions on how to remove SP3; http://support.microsoft.com/kb/950249
Did you find this helpful
Mike
May 21, 2010 | Microsoft Windows XP Home Edition
My daughter (aged 12) has loaded a copy of Vista (which were discs from a computer her grandmother no longer owns and has been scrapped) onto her laptop which had Windows XP installed. She does not have a...
Hi.
If she did not format the hard disk, then the Windows XP startup option will be present in boot option. When computer startup you will get a choice like this:
1 Microsoft Windows Vista Home Edition.
2 Microsoft Windows XP Professional SP2
In that case you can restore XP, starting on XP and editing the file winboot.ini, that is an hidden system file located on C:/ drive.
See:How to edit the Boot.ini file in Windows XP.
If instead Windows XP does not start, or if you do not get the boot option, that means that Windows XP system file had been deleted.
In that case the only way to get back Windows XP is reinstalling the system from scrap, using a Windows XP install disk, and the number listed on the licence sticker.
Regards.
Oct 23, 2009 | Microsoft Windows XP Home Edition
When i turn my computer on, it ask me to pick xp home edition or it will pick the first one on the list. I wan to know why it is doing this
This will occurs when the Computer did not shut down properly or restart automatically or a dual Operating System installed in the Computer.
To resolve this:
1. Click on Start -> Control Panel -> System.
Or, Click on Start, right click on the My Computer option and select the option Properties.
2. In the System Properties option click on Advance tab.
3. In the Advance, click on Setting option under Startup and Recovery option.
4. Under Startup and Recovery option un-check the boxes:
a. Time to display list of Operating Systems.
b. Time to display list of Recovery options when needed.
5. Then, Click OK, then Apply and OK in the System Properties window.
6. Restart the Computer.
This should resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Sep 29, 2009 | Microsoft Windows XP Home Edition
My xp home sp3 wants a least 2 restarts before it
"Wants a reboot?" That's strange.
If you have the McAffee software available for re-installation - I would remove McAffee (UNPLUG YOUR NETWORK CABLE, as you'll be naked to the world) and see if it boots OK without McAffee.
If it is happy to boot without McAffee, then try re-installing McAffee and see how it acts.
You can always use something other than McAffee if it ends up being the culprit of your problems.
Also, check for malware. Download MalWare Bytes (http://www.malwarebytes.org) and make sure to update the definitions and run it across your computer. The Quick Mode is effective, and the Thorough Mode takes hours .... :)
Just make sure to be careful when you have no AntiVirus installed to not go playing on the internet .... download MalWare Bytes (install & update) before you remove McAffee and unplug from the world.
Jun 14, 2009 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
