Question about Dryers
Scraping sound when tub is rotating.
This is a GE electric dryer, 2yr. old. Recently started a scraping sound when rotating. Sounds like something got between the tub and cabinet, like possibly gravel or metal. Don't know the Model but it is a single front load. The instrument panel at top & back reads left to right: START....FABRIC CARE.....WRINKLE CARE......SIGNAL......and round dial reading: COTTONS....EASY CARE...DELICATES....TIMED DRY.
Is there a way to view the area around the outside of tub for inspection?
Thanks for your help
Ron
  • 979 Answers
The motor turning the drum may be bad OR the spindle or axle the drum turns on may be bad as well. The belt turning the drum may have been to tight thus putting too much pressure on the drum which eventually would wear it out then causing the noise which will only get louder as time goes on.
You will need to take off the back of the dryer and possibly the top to gain proper access to the drum and motor.
Posted on Jan 14, 2009
Dryer drum is scraping against something and making a thumping noise as it spins
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Problem 1... Your scraping noise is probably coming from the drum rubbing the door as it rotates, you door seal may need replacement.
Problem 2...Your other problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 31, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Ge DPSR483EA Electric Dryer was making a scraping sound when operating now a felt like belt has come out on the inside of the dryer. What do i do? Kris Long
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 11, 2010 | GE DPSR483EA Electric Dryer
Maytag intellidryer - starts up with heat etc OK but scraping / squeeling noise, then motor cuts out
It sounds like the roller wheel that rolls the tub is bad. and this could cause the heater to over heat that would cause it to shut off. Hope this helps
Dec 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes a clicking/scraping noise when operating in the heated settings. The noise does not occur when using air only setting. I disconected the gas and ran the dryer and the noise remained. It is only...
since it not happening in the non heated cycls and with out being able to realy diagnose
the clicking is your gas turning on and off
the scapring could be a couple things,,, the tub getting hot and expandin g just a bit,, or your hearing the scream of the flame
many time speopl have complaind that the heat sounds like something is scraping
Oct 26, 2009 | Dryers
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
Grinding, scraping noise when drying
Glides or roller replacement, could also be something from a pocket wedge between drum or cabinet.
Feb 01, 2009 | GE DBSR453EBWW Electric Dryer
Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
GE Spacemaker dryer scraping metalic sound when on
i know you say ge dryer but i think thats a frigadire inside ge dosent make an over under.When dryer off take your hand and go around the in side of the tub where it meets the felt seal.some times somthimes somthing will get caught between the turning drum and the felt seal causing a noise.if not that you have some wear problems and will have to take apart to inspect
Dec 31, 2008 | GE Spacemaker Washer and Dryer Electric...
Loud Grinding noise in Dryer
I know this prob is old, but I had the very same prob with my dryer (very loud squeaking noise). The prob was that there was a screw stuck between the rotating part and the stationary part. Meaning - look inside the dryer (main area - where the clothes go) and rotate it by hand. You may hear and see something causing the friction. Gerard
Dec 29, 2008 | GE DSXH47EGWW Electric Dryer
Old whirlpool mini dryer
Those are front tub supports that keep the tub from scraping.Unless you start hearing a rubbing or scraping sound your dryer is ok.Just keep a ear open for awhile for any scraping sound.If you need help in the future with anything ,Im more than happy to help you.
May 24, 2008 | Dryers
Dryers Logo
175 people viewed this question
Top Dryers Experts
