Home | Zanussi | FJS1225W Front Load Washer | Jetsystem blocked.
Zanussi FJS1225W Front Load Washer
Problem for Zanussi FJS1225W Front Load Washer
Jetsystem blocked.
By RebeccaCR on Jan 14, 2009
I have a Zanussi Jetsystem 1400 and the jetsystem (the tube that squirts water into the washing) is really blocked and just trickles out. I have cleaned out the bit of the spout I can get to - but how can I clean out all the pipes leading to it? It seems to be gunged up with washing powder, fluff etc.
Same Problem
Feb 18, 2009
-   Just found your post while looking for solution to the same problem on a FJDR1466W...
Worked great when new but water just trickles out of the jetsystem drum feed pipe.-   Guest
Jan 16, 2009
-   I have the same problem that that on C wash - my washer does not take the soap and you can hear just a trickle of water going through. It takes ages to wash on the c wash. Wherea, If I put on the G wash, it seems to take the soap, the fabric conditioner and washes. I am not sure that it happening. Can anyone tell me how to resolve. Or whether it is expensive to repair, and just purchase a new one.-   Guest
Solution #1
posted on Jun 07, 2009
Not Rated)
esgrhodes
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem, if you undo the self adjusting clip that holds the drum seal in - then pull back the top of the seal near the nozzle thats blocked, this will reveal the pipework attached to the nozzle.
Then use a pipe cleaner and push up through nozzle - the attached pipe is clear so you will see any gunge and be able to loosen the debris.
After cleaning reassemble seal then run a empty cycle which will clear the loosened debris.
Regards,
Grant
Was this helpful?
Yes
No
Popular Solutions for Zanussi FJS1225W Front Load
Questions and Unsolved Problems for Zanussi FJS1225W Front Load
Do you recommend Zanussi FJS1225W Front Load Washer?
Answer
Answer
i keep getting error messgae e20 when using dryer part of zanussi jetsystem turbodry 1200. it just... (More)
Answer
1220S Machine. Started but would not spin. Will not restart now.
Answer
not spinning as fast as should and washing very wet at end
Answer
Zanussi Jetsystem 1200 - Hello, The fabric conditioner does not drain into the machine and remains... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zanussi FJS1225W Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14118
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
