Question about HP iPAQ RZ1710 Pocket PC
Hp stucked in initial screen - HP iPAQ RZ1710 Pocket PC
  • carlinhos138
    carlinhos138 Dec 17, 2012
    The problem started when I tried to restart de PPC since many months of innactivity. The first screen that appears was the allignment screen and then a tutorial. In that tutorial in the second part when you have to try to copy a meeting point there it doesn't react anymore.
HP Designjet 130 not initializing...
If there a jetdirect network card trying removing it and restarting.
Nov 11, 2014 | HP HEWLETT PACKARD Designjet 130 printer...
In my hp 8440P, wen i install har disk, it stops booting even stucks on initial HP Logo screen n dont enter into BIOS even!..Whilst when i remove hardisk, it smoothly boots via cd room..plz help
If the hard drive causes this problem it is most likely defective. Try with another hard drive and if this works, problem solved. I had a bad ROM drive that caused the same problem, I swapped it out and the computer worked perfect.
Aug 14, 2013 | Computers & Internet
HP F1703 Screen goes black within seconds of startup
That is either the backlight or its power supply.
This is a bit tricky as you can get it fixed under warrenty but they will likely ask you to send back the entire computer not just the monitor. It is also something that you could fix or several shops could but the repair cost really isn't much less than a new monitor. You are not stuck using an HP monitor so anything will work and you can get quite a lot bigger or better for about $120 and up. Repair cost is going to be $80-$100 so as you can see for just a few dollars more you have a new warrentied monitor.
Apr 27, 2010 | HP Pavilion F1703 17" LCD Monitor
Constant Initialization
i would start by removing all paper trays, optional memory, network card, etc to see if it boots up then.
Mar 12, 2009 | HP LaserJet 1600 Printer
HP G85 is stuck on "Initializing"
Sounds like your main board has gone out on this unit. We can sell you a replacment board for $45 if interested. Its not too terribly hard to install.
Inkworks
866-381-0541
Nov 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Cannot run printer...stuck on Initializing
hi,
please go through the following link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01330821&cc=us&lc=en&dlc=en&product=390328
thanks and regards
agnel
Jul 15, 2008 | HP PSC 1610v All-in-One Printer
Printer not working
buy a new printer. Since you give no specifics..make or model number..get a new one..HP or Canon.
Jul 04, 2008 | Office Equipment & Supplies
HP iPAQ RZ1710 Pocket PC Logo
91 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
