Question about Garmin 200/50khz, 10/40deg, Plastic, Transom Mount, Depth, Temp
Need garmin 178c transducer pinout or wiring diagram/ Information
  • eastwood7 May 11, 2010
    Do you still need this?? I can send it tomorrow. It would be the schematic for the back of the Garmin 178C. That should have the ducer pinouts.
SOURCE: Sounder transducer?
I believe like my own Garmin I have a 178 which is the mono version, same transducer though, you alter the frequencey setting in your main reciever set up program.
Posted on Sep 26, 2008
Garmin GPSMAP 178C not boot
can we download india map?if tell me how to download and install the map in my device Gm4300?
Nov 20, 2013 | Garmin GPSMAP 178C Sounder GPS Receiver
My Garmin GPSMAP 178C screen backlight failed
Backlight problem: Remove the display, remove the light tube from behind the LCD. Buy a led panel from Ebay for around $5 and install it behind the LCD under the drfusing layers. Run the wires out to a 12 VDC source and there you have it.
Jul 13, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
GPSMAP 178C Sounder GPS Receiver: My 178C will not stay powered up. I just replaced ...
I had the same problem with mine. It is caused by a crimped wire on the internal harness inside the machine. I opened it up and discovered that when originally put together 3 of the wires from the plug were crimped. One was broken off. The only way to fix it is to open it up, restrip the wires place a piece shrink wrap on before you solder it back and then make the shrink wrap flush with the back of the plug and heat her up. And, Voila... no more intermittent operation. Hope this helps? John
May 18, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin 178c turns off on it's own.
Hi
Sounds very much like the wiring plug connections in the back, always overlooked but so important that connections are tight and contacting.
Jul 06, 2009 | Garmin GPSMAP 178C GPS Receiver
Where do all the wiring go to on the garmin 400c
The rest of the wires are for interfacing (letting the unit 'talk') with other devices such as radar or GPS. These wires/colors are pretty standard and defined by NEMA (National Electrical Manufacturers Association). You need wiring diagrams for the devices to hook them up. For fun, see where 'nema' takes you with Google.
Jun 18, 2009 | Garmin Fishfinder 400c With Dual Beam...
Garmin 178C Stays on for 20 secs then turns off
I had the same problem. In your settings you can set this thing to monitor your battery's power so it auto shut down if your battery goes below 11.2 volts or so. I disabled this and it has worked ever since.
Jun 16, 2009 | Garmin GPSMAP 178C Sounder GPS Receiver
Need older Raytheon v720/ v820 sounder transducer pinout
Did you find it? i´m triying to get a wiring pinout diagram for a V8010 transducer. Thanks, regards from Spain
Apr 21, 2009 | Televison & Video
Sounder transducer?
Sep 11, 2008 | Garmin 200/50khz, 10/40deg, Plastic,...
Garmin 200/50khz, 10/40deg, Plastic, Transom Mount, Depth, Temp Logo
869 people viewed this question
Top Garmin Boating Experts
TO Lady
SBITSdotBiz
Level 1 Expert
Are you a Garmin Boating Expert? Answer questions, earn points and help others
