Question about Linksys Wireless-G WRT54G Router
No connection I was setting up a wireless router for the first time and at the end of the CD setup, it asks for a 5 digit password, which I never set or received with the router. I have one PC and three mac computers. The PC is the host computer. I have optimum online (cablevision).
Live the username bLank and key in admin for the password ..
Posted on Apr 18, 2009
  • 827 Answers
The default password for your router is 'admin'
Hope this helps
Chris (ziraffa)
Posted on Jan 14, 2009
INetwork Password
ask your internet service provider
May 30, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
How to change password for wrh54g. i lost my set-up cd.
Hi Friend,
Please follow the steps in order to resolve the issue:
1.Connect the router to a computer.
2.Type 192.168.1.1 in the web browser and hit enter
3.Enter the username and password(default password is admin and leve the username blank)
4.On the setup page click "Wireless" tab and fill the sections as mentioned
Wireless network Mode:Mixed
Wireless network Name-As per your choice
Wireless Channel-6-2.437GHz
Wireless RF Control-Standard
Wireless SSID Broadcast-Enable
Wireless RF-Disable and click Save Settings.
5.Click Wireless Security and fill the sections as mentioned;
Security Mode-WEP
WEP Encryption 64 bits 10Hex digits
Key1-Enter 10 digit or 10 letter password(example-your telephone number) and click Save Settings
6.Click Advanced Wireless Settings and fill the sections:
Beacon Interval-75
Fragmentation Threshold-2306
RTS Threshold-2307 and click Save settings.
7.Click Access Restrictions
From here you can able to restrict the number of users for your computer. You can set the parameters based on days and time.
After you set the restriction policy click Save Settings and turn off the router for 30 Seconds and then turn it on.
Try to connect your wireless devices.
Regards
Chiranjeet
May 28, 2010 | Linksys Wireless-G Broadband Router
Wireless indicator light off when turn on the router
Option 1:
Possible reason why your computer is not getting online wirelessly is because the wireless settings on the router and the wireless settings on your computer do not match. Here are some troubleshooting steps that I suggest you try:
A. Checking the Wireless Settings of the Router
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Open any web browser like Internet Explorer or Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. When the setup page opens, click on the Wireless Settings under Setup and take note of the SSID.
5. You may also change the wireless channel here. We suggest channels 1, 6 and 11.
6. At the bottom of the page, look for the Security Options. If in case that the security is set to WEP or WPA-PSK, we have to enter the same wireless security on all wireless PCs. To make sure of the key, we can try modifying the security. Please refer to the following:
For WEP: Select Key 1 and enter 10 hexadecimal digits (0-9 and A-F) on the empty box beside it. Then, click on Apply.
For WPA-PSK: Enter an alphanumeric key (minimum of 8 characters) on the Passphrase box and click on Apply.
Note: The Key and Passphrase are case-sensitive.
7. On the left pane, please scroll down and click on Wireless Settings under Advanced. Please make sure that the boxes for Enable Wireless Router Radio and Enable SSID Broadcast are checked.
8. Click on the Setup Access List button and uncheck the box Turn Access Control On.
9. Click the Apply button.
B. Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
We hope that the above steps provided would help resolve the problem. If the steps above did not work, we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Option 2
1. Please open any web browser like Internet Explorer or Mozilla Firefox.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
May 03, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
How to get my wep
For Windows Vista:
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
Apr 26, 2010 | NetGear RangeMax WPN824 Router
Cannot get HP advisor to locate the router on my laptop. However, the desktop is working. Note: my desktop is XP and the laptop is Vista.
1. Open any web browser like Internet Explorer or Netscape Navigator.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
For Windows Vista:
Aug 18, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Netgear Wireless router logon problems
You probably typed in the router password instead of the Wireless password. Connect your PC to the router via a network cable type in your web bvrowser 192.168.1.1 , login to the router and in the Wireless security section change the passphrase to something and write it down then try re-connecting via wireless after unconnecting the net cable
Aug 09, 2009 | NetGear WNR2000 Wireless Router
Its not transmitting the wireless signal to my laptop. i'm being asked for a security key. where do i find it?
o Wireless Connection Found in Range
1. Please open any web browser like Internet Explorer or Netscape Navigator.
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
Note: If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
For Windows Vista:
Jul 12, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
I forgot my pass phrase...what now?
For Windows Vista:
Jun 26, 2009 | NetGear WGR614 Wireless Router
I have new Sony Vaio Laptop and Sony Vaio All in One computers with internal Intel (R) Wireless WiFi Link 5100 network adapters and I am trying to connect to a Rangemax WPN824 (MIMO) router. I can see the...
For Windows Vista:
Jan 01, 2009 | NetGear RangeMax WPN824 Wireless Router...
I cart my IBM Thinkpad Lenova T60 back and forth to/from work and work from home 1/2 the time. Computer stays on most of the time and connects via docking station at work and wireless Netgear RangeMax at...
change the wireless security to WEP or WPA-PSK (TKIP)
For Windows Vista:
Dec 30, 2008 | NetGear RANGEMAX WNR834M Router...
Linksys Wireless-G WRT54G Router Logo
101 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
