Question about Prestige Remote Start
AUDISVOX REMOTE START APS-620 WONT START AT TIMES.
I HAVE A 2003 TRAILBLAZER. I HAVE THE APS-620 REMOTE START AND SOMETIMES THE TRUCK WONT START. IT WILL START AND RUN FOR 2 SECONDS AND TURN OFF. AND IT WILL TRY IT 2 MORE TIMES THEN TURN THE REMOTE START OFF. AND SOMETIMES IT WILL START AND SOMETIMES IT WONT
  • rbadh91 Jan 24, 2009
    I have same problem, but I have either APS786 or APS686 (not sure which one). The locks don't work from the remote some times, and the remote start does not work often. When it does work, it will try to start the car, but does not and re-try's for few times.
    Any luck??
  • Anonymous Mar 31, 2014
    started this morn 150 ft when sat out all nite.
    but then it wouldn'nt start when closer from different angles.
    Problem Solver:
  • 12 Answers
I am an mecp first class certified mobile installation technician with over 10 years experience. email me at face2face11@bellsouth.net and i'll see if i can help
Posted on Jan 15, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Is a autocommand model 21921 remote starter compatible with 2007 chevy trailblazer with factory keyless entry
go to IDATALINK.com,you can enter your car specs and buy correct interface module, door locks park lights dome lights and ignition module.i installed audiovox aps 997c remote start alarm with their module works like a champ.VERY INVOLVED INSTALL
Jan 19, 2013 | Design Tech Vehicle Parts & Accessories
SECURITY SYSTEM SOMETIMES WON,T LET CAR START IF YOU STICK THE KEY IN SOMETIMES IN WON,T START. WHAT CAN I DO TO FIX THE PROBLEM?
check the key if its worn down or damaged the truck wont recognize the key and security will activate if its worn will have to get a new key cut and if an electronic key will have to program
Oct 22, 2011 | 2006 Chevrolet Trailblazer
Tailgate on a 2002 trailblazer will not open. unlock button wont let it open. what fuse do I need to check or do I open from inside?
  • There was a Technical Service Bulletin concerning this.
  • Bulletin No.: 03-08-52-002
  • Date: March 27, 2003
  • Technical - Subject:
  • Remote Keyless Entry Inoperative (Reprogram Liftgate Module)
  • Models:
  • 2002-2003 Chevrolet TrailBlazer, TrailBlazer EXT
  • 2002-2003 GMC Envoy, Envoy XL
  • 2002-2003 Oldsmobile Bravada
  • Condition
  • Some customers may comment that the Remote Keyless Entry (RKE) is inoperative at times.
  • Cause
  • An anomaly has been identified with the software in the Liftgate Module (RKE functions). The Liftgate Module software is affected when the temperature is approximately 40°C (104°F).
  • Correction
  • Using normal SPS reprogramming procedures, reprogram the LGM Liftgate module. The information was released on TIS version 2.75 or newer broadcast in March 2003.
  • There is a fuse block under the rear seat on the drivers side. Fuse # 3 and # ^ are the ones you will check for the Lift Gate.
  • Often the problem can be in the harness going to the module.
  • Sometimes the module needs replaced and then reprogrammed.
  • Here is a copy of your owners manual for free http://www.extendedgmwarranty.com/owners-manual/chevrolet/2002-Chevrolet-TrailBlazer.pdf
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 01, 2011 | 2002 Chevrolet TrailBlazer
I was sriving my 2003 chevy trailblazer and the gauges went crazy and died now it wont start and no power to the gauges and wont come out of park
First check the battery and its cable connections, second, try working the ignition switch several times. After that, you will need a mechanic to check it out.
Aug 13, 2011 | 2003 Chevrolet TrailBlazer
'05 Grand prix-Installing an APS-620N remote starter unit....Will only start with key in ignition???confused. Thanks.
The vehicle requires a bypass module. If you are using one of your keys and an antenna ring to bypass the immobilizer, you still need to make a connection at the keysense wire. The keysense wire is light green at the ignition harness. If you are using the - status wire(ground when running)(light blue) from the 620 for the keysense and the immobilizer; double diode the wire.
Jan 20, 2011 | APS620N
Car starts then stalls I have installed a Pretige remote car starter on My 2005 Cadillac Escalade EXT. I have the bypass installed with the key in it. The truck starts then stalls. Any answers?
You have the wrong bypass. The bypass you are using is for universal transponders. You need the Passlock 2 bypass. The passlock is a resistance that is read from your ignition cylinder by the bcm that will allow your truck to start.
Jan 20, 2011 | APS-901 Prestige Remote Start
2003 Chevy Trailblazer wont start
it sounds like your battery is dead charge it and try again if the starter still clicks it means it is sticking get someone to turn the key while you hit the starter body with the handle of a hammer which will free it of
Apr 01, 2010 | 2003 Chevrolet Trailblazer Ext
Remote starter does not work but will unlock and lock doors.
depending on your alarm which it sounds like a viper model maybe? on my 02 you have to incorporate a factory alarm bypass module in order to be able to start the truck, they run about 100.00 bucks and have to be profssionally installed. The truck wont start because the computer isnt recieving the proper starting sequence due to the factory alarm
Jan 11, 2009 | 2003 GMC Sierra 1500
Prestige Remote Start Logo
779 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
