Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
The washer dryer was on a 45 minute drying cycle, loud popping noise heard then fuse went. Husband replaced fuse now machine will wash ok but I can't use the dryer. Please help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Posted on Jan 27, 2009
Washed ok but when put on drying mode it made a loud grating noise
The drying fan is most likely clogged.
Take of the topp, then you will se the drying fan. Along with the heating system. There are several screws you have to undo on the heating canal. Then you should be able to clean the whole thing.
Sometimes the fan is broken, and need replacing.
This is not recomended if you dont know what you are doing!
Do a mistake with the overheating guards, heater position, wireing ect, and you could set the machine on fire the next time you use the dryer
May 14, 2014 | Hotpoint Washing Machines
The last 5 minutes of my washing cycle, my washer makes this loud noise! It sounds like a plane taking off! It's so loud, you can't hear tv. I'm not sure what the problem is.
Does it dry the clothes as fast as always? Or is it taking longer to dry them? That noise could be the blower wheel.
If the noise is more of a scrubbing sound that would be your glides worn thin and rubbing the mount
Something can also be in the blower causing the noise.
9_20_2011_2_48_43_pm.jpgTake the door off first and since the door is reversable remove those 2 screws on the other side. Then the front pops off revealing the clips that hold down the top. Then you can get the glide mount/shroud off there and remove the tub. You probably figured out you cannot access the innards from the rear of the dryer.
http://www.fixya.com/support/r6555743-help_maytag_slopefront_dryer_died
Sep 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Feb 05, 2010 | Hotpoint Aquarius WD640 Front Load...
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Aquarias wd 420 hotpoint
sound like motors or heaters have a short good luck.
Sep 13, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
My hotpoint vtd00 dryer seems to have stopped drying
Have you cleaned the exhaust ducting? The duct that runs from inside to outside. Try that first. Sounds like your exhaust line is blocked. Also with the filter out get a flash light and look down the venting if alot of lint vaccum out. NOTE: Unplug the unit, wheather gas or electric.....and if it is a gas shut off the gas to the dryer before moving just in case something gets loose while moving. Hope this helps.
Nov 11, 2007 | Hotpoint NWXR473EV Dryer
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Aug 15, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
134 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
