Question about Sharp Zaurus SL-5500 Handheld
Locks up.. it just locks up and the screen stays on but it has lines though it. It comes back with a reset. thanks
0 characters
1 Points
Htc 8s water damaged?
It is a water demage - with using to quickly you made it bad, I guess with pressing the screen you moved the water.
I would say ... give it another dry (smile)
Open the rear, take the batterie out ... mean let the mobile breath ... then leave it on a warm, but not hot place ... it has to stay on the side. We want that the water in the case vabours troughthrough the side buttos within the time.
Feb 04, 2014 | PDAs
System goes to the time/date screen, and then when you touch "Done" the system locks up.
Try first removing PDA battery and sse if reset. If you can bypass the date screen you can also do a master reset from ' settings' menu.
The firmware in your pda is corrupted , it must be reinstalled, provide make and model thanks.
Jul 23, 2008 | PDAs
Fatal alert memorymgr.c,Line:3732
Just happened to me after installing ThinkOffice. There is a reset button just below the labe "Made in China" on the back of the unit. Hold that button in with your stylus.
Nov 18, 2008 | Palm Tungsten E2 Handheld
My mio p350 was playing up. it then hard reset it self. it came back on line and was working for a few minutes then stalled. i soft reset it and now it will not come back. it stays on the first page...
Mio P350/550 Hard Reset 1. Turn off the pocket pc (on/off button ).
2. Push the joystick button up (to the screen).
3. Turn on the pocket pc.
4. keep holding on the joystick button for 30 second.
Oct 30, 2008 | PDAs
My tmobile dash keeps going back to the home screen
Hi jamari140,
A few questions to get a better idea of what this might be:
1) Are there any applications that open successfully?
2) Which keys/buttons are you pressing to enter these apps?
3) Have you been experiencing any issues with the keyboard (incorrect key sequences or letters, etc.)?
Please respond to the above and we'll dive a little deeper into what's going on here.
Sep 30, 2008 | T-Mobile Dash Smartphone
Treo 700p locks on Access Powered
I called Sprint tech support. With the battery in, hold the red power button down until the screen comes on that asks you if you're sure you want to reset your Treo (you will lose all information but hopefully you're like me and synch it frequently with your desktop.) I reset it and then synched it with my desktop and got almost all my info back - just had to redo email passwords and some settings. It was easy.
Sep 29, 2008 | Palm Treo 700p Smartphone
Password reset
If you forgot your password you can try guessing until 3-5 tries and if t locks there is a pin that can open it that came with your phone company, better yet call your phone manufacturer so they can walk you through the steps and give you codes as well
Jul 22, 2008 | Samsung SGH-E840 Smartphone
Unit locks up to reset Screen
Try pressing the reset button on the back
Mar 31, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Sidekick II reset:
Drain your battery until your phone refuses to turn on, then charge it, the privacy lock should be off.
Press and hold the Menu key (the one with 3 lines) + the shift key and finally the "Q" key all at once.
Okay so you're at the privacy lock screen.
Okay press the Menu key and the Phone Mode key (the one with the circles) at the same time.
This should take you to emergency phone calls
Hold down the Back key (the one with the arrow) DON'T LET IT GO.
Now press MENU and PHONE MODE at the same time, now let go the BACK KEY
Then press BACK again and let go of MENU and PHONE.
Now press MENU and PHONE again and then let go of BACK.
It takes like 3 times to unlock it
but it always works.
Jan 21, 2008 | T-Mobile Sidekick II
K-Jam locks itself on phone screeen
Reformat it, basically go through a hard reset and reinstall the firmware Here is how to hard-reset your MDA/Wizard using a key combo - courtesy of a smart T-Mobile tech support help desk guy who wrote a note about it as it's not in official help doc's: 1. Simultaneously hold down the Communication Manager and Voice Dial buttons and put the Soft Reset 'button' with the stylus tip - all at the same time. 2. You see a very scary looking black screen with white letters in System font reading something along the lines of ?Are You Sure? Press Send key to continue.? 3. When you push the 'Send' key, the Green pick-up the phone key process starts 4. Next you will see what made me smile like a kid - Formatting FAT partition and very briefly in matter of few seconds began normal first boot.
Aug 20, 2007 | i-mate K-jam Smartphone
Sharp Zaurus SL-5500 Handheld Logo
20 people viewed this question
Top Sharp PDAs Experts
Lawrence Oravetz
Are you a Sharp PDA Expert? Answer questions, earn points and help others
