Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Bulb Replacement for Sony TV KDF-42WE655
May I use a Philips Bulb P22 100/120 W serial # 8A80153 instead of the Sony XL -2400 bulb. Any tips about replacing the bulb-I did not purchase the housing, only the bulb. Do you recommend that or both housing and bulb.
Thank you
  • 294 Answers
No you should only replace a bulb with the one made for that brande t.v. you should put in a sony xl-2400 in your sony t.v. and yes you should get both housing and bulb in 1 i bought mine off ebay for about 116.00$ both lamp and housing very easy to replace good luck also if you have a sony kdf-42we655 or 50we655the lamp part # is xl-21oou or xl-2100
Posted on Mar 14, 2009
When i turn my tv on,after like half minutes tv turn off by self than starting turning on and off every half minutes....do you think is bulb problem or something als?thx
Symptom shows it is bulb problem that needs to be replaced too solve tv issue.
Existing lamp/ bulb in tv has reached an end of its working life span but still not dead/ broken and causing this problem.
Buy Sony original lamp for good picture and replace it.
Thanks.
Nov 04, 2010 | Sony (XL-2400) Projector Lamp for...
Tip
Sony DLP Lamp XL-2400 How-To Replacement Guide. For Part Number: Sony Lamp...
For Part Number: Sony Lamp XL-2400 ( Sealed replacement lamp for televisions, SMALL & SEALED ).
Compatible Part Numbers: XL-2400, XL2400, XL-2400U, XL2400U, XL-2400E, XL2400E, F93087500, F-930-8750-0, A1129776A, A-112-9776-A
For Enclosure: Sony Lamp ( XL-2400 / 2-590-738 ).
Television Type: 3LCD.
For Bulb: UHP 120 / 100w 1.0 E 19.8
Philips UHP 120 / 100w 1.0
E 19.8 1.0 Philips.
on Mar 25, 2010 | Televison & Video
My tv is on standby and will not turn on
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service
Jul 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Its in standby mode the light keeps flashin but it want come on. I have unplug it and everything
Don't panic, you have a bulb failure. This is normal after a few years of use.
Go here to see the correct bulb for your Sony. You need XL-2100.
Sony Lamp Gallery
Use the correct bulb for your model and if you are uncomfortable with the replacement procedure, get local service.
Jun 07, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i install a replacement xl 2400 lamp within a housing unit into my sony wega kdf46e2000 tv??????
how do I REPLACE THE LAMP IN THE kdf-42WE-655 WEGA TV. i PURCHASED THE REPLACEMENT LAMP, PART NO. XL-2100U>
Sep 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-60XS955 Blue dots all over screen. Lower left corner of screen has a small blue cone shape. Will a new bulb fix this? If yes how do I replace the bulb?
It is problem of light engine (optical block) in TV and Lamp replacement does not solve it.
TV needs replacement of light engine, that is costly part.
Jun 20, 2009 | Sony KDF-42WE655 Television
Wrong model number listed in my original question
I gave you exact and correct lamp part number of KDF-E55A20 and explained in previous reply that there is no difference between XL-2200 and XL-2200U lamp. both are same, first on came with new TV and second one is its replacement number.
KV-36FV26 is CRT TV and has no lamp inside.
May 18, 2009 | Sony KV-36FV26 TV
I have a 2004 Sony LCD projection TV. The set
It is symptom of weak Lamp (bulb) that requires replacement.
You can buy Sony original lamp from Sony Accessories Store.
Lamp required for KDF-42WE655 part number is as follows..
A1606034B LAMP BLOCK XL-2100U
May 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
6 blinking lights after changing replacement bulb
You have an open thermal fuse in the lamp housing. The fuse has an upgrade and is only accessible from the back of the TV>
Apr 15, 2009 | Televison & Video
Xl 2400 bulb replacement
Go to
www.dlplampguide.com
and select your set model and watch the video which is a YouTube video. Shows entire bulb replacement start to finish.
Jul 07, 2008 | Sony (XL-2400) Projector Lamp for...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
258 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
