Question about RCA DRC277 DVD Player
DRC277a red light only
I have a dvd player DRC277. The red light is on but i am am getting no other signal from it that things work. The red light is the on/standby light.
  • 1 more comment
  • msakaz Feb 06, 2009
    I have the same problem. The red light is, but nothing else works. The open/close button on the dvd player or on the remote don't even open the door for the disc.
  • Anonymous Feb 10, 2009
    i have the same problem with my player and the only way i can use it is to unplug it and plug it back in, it also stops playing during a dvd and the same procedure has to be done to get it to play
  • joy chowdhury
    joy chowdhury May 10, 2014
    Helped a lot, thanks msakaz...
The red light on my player is on when the unit is off and it is on when in the standby or play mode.
Posted on Mar 05, 2009
The red light means it's on standby.
Heh.. Basically, you're trying to get it to work with the power turned off :)
Try turning it on, you'll probably get a signal.
Posted on Apr 14, 2009
SOURCE:
Can't get green standby light to stay on, so can eject DVD from combined TV and DVD player.
First try unplugging and plugging back in then remove caseing and insert paper clip under locking mechanism and hit eject...your locking mechanism signals that there's no cd in it and so to it there's no dvd or cd...hope that helps:)
Jan 04, 2012 | Televison & Video
I have a 40" Toshiba and the DVD player has the
some players have a switch on the back to change it's output its most likely progressive your looking for if not on the player look on the remote ok good luck with it
Dec 21, 2010 | RCA DRC277 DVD Player
Everytime I put in a disk in the player it searches and comes up no disk. I tried using my cleaning disk and it doesn't even acknowledge it. The dvd player is a RCA DRC277
Hi...The only other thing you can do is:
UNPLUG from the AC..Take the top case off and see if there is any access to the laser lens..( very small "1/8th inch" clear plastic)
If you can , clean it( VERY lightly) with swab of 90% alcohol
Sep 01, 2010 | RCA DRC277 DVD Player
Why won't my TV pick up my DVD connection? The player works fine, but the TV isn't showing the picture. What do I do?
Are you sure you are selecting the Audio Visual Input? The wire are color to color Yellow to Yellow, Red to Red, White to White. Ensure you have it in the correct Video IN and Audio IN and have selected and the correct AV input on the TV.
Feb 06, 2010 | RCA DRC277 DVD Player
Will the rca dvd drc277 play video cd-r?
Yes it will !
DVD Video · DVD-R · DVD-RW · DVD+R · DVD+RW · CD (Audio) · CD-R · CD-RW · Picture CD are all listed in the product specifications
Aug 07, 2009 | RCA DRC277 DVD Player
Can not use Vizio or Direct TV remote to control RCA DRC277 DVD
I took this piece of junk back to Target and got my money back.
Jun 26, 2009 | RCA DRC277 DVD Player
Remote code for RCA DRC277
my rca dvd player model # drc277 will not play .i put a dvd in and it opens and closes. Is there a code to play all region disc?
Jun 21, 2009 | RCA DRC277 DVD Player
RCA DRC277-A, No sound when played through a Samsung HDTV using the HDMI chord. Chord and TV seem to check out fine. Tried all buttons and menus I could find. Have set sound to PCM, etc.
There might be a setting in your tv's audio menu to enable your audio source, which is now hdmi (vs. the rca-type red and white audio cables). Once you select the type of audio you are using, the audio, you should hopefully be able to get sound from your dvd player now.
May 31, 2009 | RCA DRC277 DVD Player
How do i hook up my rca dvd to my samsung tv its hooked up right but i can'y figure out how to get the tv on the right channel for it to work
This DVD player only has audio and video outputs. You'll need to connect it through one of your TV's A/V inputs, then switch to that input to see the DVD signal.
If your TV doesn't have A/V inputs available, you'll need to connect the DVD player using an RF converter. This takes the audio and video signals from the DVD and produces a channel 3 or 4 output you tune in on your TV. Converters cost around $10 to $20 and are available at Radio Shack or retailers who sell TV's.
Feb 23, 2009 | RCA DRC277 DVD Player
Memorex DVD player won't work
the standby light switch is your on/off switch as well......
Nov 18, 2008 | Memorex MVD2042 DVD Player
RCA DRC277 DVD Player Logo
1,283 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
