Question about Refrigerators
My kenmore freezer wont auto defrost
The freezer portion of my refridgerator wont auto defrost I defrost manually and it works fine until the frost builds up then it doesnt cool
mikedurland
  • 481 Answers
SOURCE: Viking freezer frost build-up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 21, 2008
  • 245 Answers
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Posted on Jun 26, 2009
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
  • 109 Answers
SOURCE: Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Posted on Oct 22, 2009
aasc
  • 1606 Answers
SOURCE: Refridgerator side not cooling, there is a lot of
Most likely , the problem is a bad defrost heater , pt # WR51X10055 , but I would still suggest going thru the motions to make sure . The heater runs about $45.00 .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature
Posted on Oct 05, 2010
Refridgerator Stopped working , Freezer Ok
It is your defrost heater, you can get them from marcone.com with just your model number. Also at that web site you will get a exploded view of your unit. thiswill allow you to see the location of the heaters so you can just replace where the frost develops.
May 02, 2012 | Whirlpool Refrigerators
Upper portion (frig not cooling properly) Lower portion (freezer) forming ice on #3 setting.
Is it forming ice or frost? It sounds like an automatic defrost problem. If the freezer frosts up it won't circulate enough air up to the fresh food compartment. Try defrosting it manually for 24 hours by shutting it down and leaving the freezer door open. Afterwards, if it resumes normal operation I would bet that there is something faulty in the defrost circuit, i.e., defrost heater not working or defrost control.
Feb 23, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My freezer works fine but refridgerator is wont get very cold
If freezer is frosting up, check fan. if fan is not working in fridge the freezer will ice up and the fridge will not get cool air.
Feb 09, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refridgerator Freezer Condensation
When I observed this issue, I found the freezer not running the defrost cycle enough times, (maybe this was in the spirit of conserving energy Energy Star compliant???))
If the Defrost is working, use the diagnostic test, that may be all you need to do until the next build up of frost on the coils.
Aug 17, 2009 | Kenmore Refrigerators
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
Freezer coils completely frost (freeze) up--refridgerator warms
Sounds like the defrost timer or something in the defrost circuit. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 11, 2009 | Kenmore Refrigerators
Freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Jan 06, 2009 | Maytag Refrigerators
The refrigerator section is not cold enough but the freezer is fine on my Whirlpool top freezer unit. my refridgerator isn't cold even with it turned all the way up but the freezer is working fine. I own...
Hi thanks for the question check to see if the freezer fan is working if not replace. check to see if you have frost build up in freezer if you do you then have a no defrost problem. pull fridge away from the wall, remove the back panel, clean all lint. thanks the appliance doc
Oct 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Maytag SidebySide model MZD2766GES Fridge portion not working...
yes probably the a.d.c. but make sure all ice is defrosted from evap. coil. remove the freezer panel and use heat gun or hair dryer.
Aug 05, 2008 | Maytag MZD2766GES Side by Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Refrigerators Logo
190 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
