Question about Hotpoint WMA46 Front Load Washer
Pre wash not happening
The washing machine turns on, select the programme and press start. It sounds like its trying to fill up for a few seconds and then stops. Its able to spin but then it eventually stops and the pre wash light flashes. We've tried it on spin only and that works so was thinking it must be something to do with the water level guage or something. Help?!!
  • Anonymous Mar 28, 2014
    The machine appears to be over filling with water, when this gets approximatively half way up the door the pre wash light starts to flash and everything stops including the water. It will do a slow of fast spin with no problems and will drain fully, any ideas
  • 67 Answers
Poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
Posted on Jun 28, 2007
2 Suggested Answers
  • 353 Answers
SOURCE: It won't do a pre-wash. If I select the programme
could be faulty hot water valve
Posted on Jun 11, 2010
Testimonial: "Aha, you could be right there but not with it being a faulty valve, but with there not being any hot water! The machine runs off cold only and heats it up during the wash, perhaps this is why it won't do a pre-wash. Thanks I think that could be the reason"
Zanussi 1116
I would call an appliance tech. This definately is an advanced issue required by a tech to diagnose.
May 06, 2012 | Washing Machines
My machine keeps bleeping to tell me the cycle is finished but will not begin another programme ?
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time
Let me know what error codes come up, if any.
Nov 25, 2010 | Bosch Washing Machines
The washing machine will run a complete cycle perfectly, when i then empty it and refill with dirty washing, i put it onto the programme and press start, the machine sounds like the motor is running to...
On some machines when you start a programe the pump may run for a short while Restart machine and just give it a try for 3/4 minutes first just incase.
Sep 15, 2010 | Washing Machines
Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Apr 11, 2009 | Washing Machines
Timer programme
Drain pump may be obstructed or defective. You may have to call your engineer back. Maybe he disrupted something.
Nov 13, 2017 | AEG Lavamat 72640 Front Load Washer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Fisher/Paykel Smart-drive 5.5 auto washing machine was on final spin cycle and starte making unbalanced load noises. I stopped it,redistributed load and tried to restart. It restarted in spasms so I took...
sound like the controller opr micro board is sick. unplug leave off for a few minutes then power up again and try empty wash cycle if its the same call the engineers.
Apr 22, 2008 | Washing Machines
Hotpoint WMA46 Front Load Washer Logo
171 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
