Question about Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
Won't turn on
A couple of weeks my dishwasher wouldn't start. I pushed buttons and nothing happened. The next evening (fortunately before I called a repair service) it started up and worked fine..Three days ago it did the same thing, no lights, no action. I have reset the circuit breaker twice with no results. It is a Bosch SHX46A02UC and only 16 months old. Any ideas?
  • Russb Nov 07, 2007
    I'm having the same problem. Could it be the power switch? Usually the cycle choices light up when it is depressed and nothing is happening now, so I do not know if it could be the door switch, since nothing at all lights up when the switch is pressed.
The door switch is definitely not the problem if the indicator lights are not coming on. These lights are supposed to come on when the door is open.
The problem is 1 of 3 things:
1) No power to outlet that DW is plugged into;
2) Bad connection where power cord is connected to dishwasher (see very bottom front, under kick panel)
3) Some problem internal to the DW (eg., bad switch, shorted wire, etc., )
Our SHX46A is definitely having problem 3, but Bosch's manual gives zero help. So, off to find more info online or, lastly, to call Bosch repair person. Sigh.
Posted on Feb 24, 2008
1/4/2012
Our non-power problem was the controller. (The circuit board containing the wash cycle buttons). We Just had the service tech out today. Took him all of about 20 minutes. Good thing for us is that part is warrantied for 5 years and ours is 4 but less than 5.
Service call was $94.
IF We would have had to buy the part out of warranty it would have been an additional $98 or so.
Was happy that it was still under warranty but worst case would have been about $200 in this situation.
Posted on Jan 04, 2012
  • 27 Answers
Check thatr the door switch is making proper contact...try pushing the door a bit harder when closing.... C.
Posted on Jun 26, 2007
SOURCE:
My dishwasher won't start when i push the button, why ?
call a repairman .most likely the door lock switch has failed onit .
Sep 24, 2015 | Dishwashers
Dishwashers will not switch on. The power is connected, but when pushing the button, nothing happens.
Maybe you did not connect it properly in the first place. Try to ask a Tecnician to check the power Supply board cos next time you might not be able to start it
Jan 27, 2014 | Electrolux Dishwashers
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
Kitchen aid dishwasher model KUDS301XBL2 won't start
check and see if its plugged in, it might of came lose from the outlet.
Jun 12, 2012 | Dishwashers
Why my passenger side power window not roll down but locks work
That is like asking why your grass grows faster one week than the next
You use the window switch a lot --- so start there
Next, is the window regulator or cable broken -when
that happens the window usually falls down
The window motor may have fail in some way
I know you should check for a blown fuse but the other
windows work & if it did blow replacing it won't do a thing
If you have & know how to use a volt meter on any setting,
start by getting access to the switches
I doubt the locks are even on the same circuit
Personally I wouldn't even approach the vehicle
without a wiring diagram
Like going on a road trip,no map,why leave home
won't find anything or get to any place
Most people ask a question & go to a repair shop
or try thing the hard way because it costs nothing
Also gives no results
Aug 04, 2011 | Chevrolet 1500 Cars & Trucks
I have a Magic Chef dishwasher - only a couple of years old. About once every two weeks (I use it 5 times per week) it won't turn on. The only button that does anything is the delay wash button. If...
You have an intermittent contact somewhere that vibrations will every once in a while restore contact. I would clean and crimp every stinking electrical connection in the unit including the door switch. You do that, and I am sure the unit will be fine..
Sep 04, 2017 | Magic Chef CDB1500AW 24 in Builtin...
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
May 13, 2009 | Kenmore 15939 Built-in Dishwasher
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher Logo
765 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
