Question about SanDisk Sansa e260 MP3 Player
Probem with my battery
It seems i have over charged my sand disk player so right now when i switch it on it says battery too slow and then it shut down it self, please i need a help to this problem also it dont have screws at the back of it for me to atleast take the battery off for some minutes or so please i need emediate assistance to this .
    Problem Solver:
  • 5 Answers
If you over charged it, leave it shut down, unplugged. It will continue to drain some battery. A day or two should be fine.
Posted on Jan 16, 2009
My cel has got switchd off and it doesnt get connectd to d pc wen i tried to install the suite....... evn i tried charging my phone but nothing happened....... pls help me........... my mobile model is...
Hey ! Try following steps it may help you out.
1. Take out battery and insert it again then switch it on. ( if the cell is over charged so the battery will be damaged so it can be your battery problem)
2. S5233 has this fault in it like if it slips through hand on the ground so it'l make such mess like your dealing with right now. keep on trying switching it on sometimes it works.
3. make it sure that the phone is not locked try unlock key as well.
After all this if it does not work then it means that its having a hardware probem as its a touch screen phone so take it to the mobile repairing shop around and get it checked there is a probem with its I.C then.
May 04, 2011 | Samsung Star GT-S5233 Cell Phone
Player shuts off
did you use a different battery?
Mar 12, 2008 | Zenith ZPA-314 Portable DVD Player
After I power on the archos it powers down right away...I plug it in to charge and it does not say it is charging...I also can not get the power light to shut off... I have tried plugging it in to both car...
Hello :
Simply you need to replace your media player battery with new one . It seems that the battery life is ended . When battery life is ended , it can't be recharged anymore .
If that didn't help , then you need to check if the power charger is in good condition . If the power charger is in good condition , then the problem will be with the charging jack . For charging jack problem , you need to take your media player to a repair shop .
good luck .
rate please !
Mar 19, 2010 | Archos 504 500870 Digital Media Player
My sansa fuze i plug it in to the computer and it doesn't recognize the device and i have tried all usb options on the device. What do i do it wont charge at all.????
When the Fuze can be switched on:
1. slide the power on switch shortly upwards to put the player on
2. hold the power on switch upwards for 15-20 seconds
3. release the power switch
Next try to switch the player on and see if it reacts normally.
Switch the player off again and try charging again, making connection to a computer.
When charging still doesn't start, disconnect the player from the computer:
4. slide the power switch downwards into the lock position,
forcing MSC mode
5. connect the player to the computer for charging in MSC mode
for a about 3 hours.
6. while charging use the Sansa Firmware Updater to check for
updates. When not installed already download the Sansa Updater
and run this execute file.
Updates for the player can only be performed in MSC mode.
The updater only works when you're logged in to the computer having administrator's rights and running Windows operating system.
MSC mode means that the computer sees the player as a removable disk. When in MSC mode, always disconnect through the icon "safely remove hardware" in the right corner below of the computer screen.
When the display of the player doesn't react at all after the reset and charging procedure, the battery of the player can:
a. be too far empty or
b. have a fast power loss.
The load of the power supply from the USB ports might be to weak to get the player charged.
When point a. is the case, an extra power adapter connected to a wall socket, providing more power, could help.
When the battery has had many loads it can be at its end of duty cycle. Then battery replacement will be required.
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa Fuze MP3 Player
Turns off right away
You probably didn't get all the sand out and now it's preventing the lens from opening correctly prompting the camera to shut down.
Aug 16, 2009 | Polaroid T831 Digital Camera
Problem with my battery
how to convert my photos to sansa e 260
Jan 14, 2009 | SanDisk Sansa e260 MP3 Player
It seems i have over charged my sand disk player so right now when i switch it on it says battery too slow and then it shut down it self, please i need a help to this problem .
Hi teddyabout,
There are few reasons your SanDisk Player is acting up. Here are some things to try out.
Make sure the HOLD switch is turned off before you power up your player. This will sometimes cause errors in booting.
If that doesn't work you can try a soft-reset by holding the power button down for 15 seconds then try turning the player on normally again.
Finally, if you are brave enough, you can take the battery out of the player to force a complete reset of the player and battery. This is done by taking the four screws out of the back of the player and removing the battery. After 30 seconds, put the battery back (be sure the it is seated properly) and replace the screws.
Good luck
Jan 14, 2009 | SanDisk Sansa e200 MP3 Player
Won't start--No Sandisk display.
my sand disk shows the sand disk display and turn offs.please give me a solution.
Dec 30, 2008 | SanDisk Sansa MP3 Player
My mp3 player will not turn on
Try connecting it to your computer if you haven't already.
If it will connect to your computer make sure you've got a back up of the songs on it then format it. Formating it may resolve this probem, it could just be a software boot failure.
To format go to "Start" then click on "My Computer" now when your mp3 players connected look for it, it's usally named as "Removable Disk", now when you've found that "Right-click" on it then click "Format" allow format to complete put the music back on then unplug and try again.
Good luck. Hope my solution was helpful in some way.
Nov 24, 2007 | iLO (2 GB) MP3 Player
SanDisk Sansa e260 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
