Question about Kenmore HE2 Plus Front Load Washer
Replacing spring wire on kenmore front loader HE 2
I replaced the bellows on my kenmore he2 front loader, but am having trouble getting the wire that has the spring on it back on. how do i do it? thanks
  • 3 Answers
THIS WORKS!!! Don't read any further. Somebody deeper in this thread came up with this. Pure genius! Take a short piece 6" to 7" long of wood. A 1 x 2 worked great for me. Drive a couple of nails into the narrow edge 5" apart. Nip off (or cut off, I used a Dremel cutting wheel) the nail heads to leave about 1/2" of nail shaft sticking out. Put the loop of one side of the wire, not the spring, and stretch the spring and put the other loop over the second spring. The loop is now big enough to fit over the boot lip. Dress the loop around the boot to sit in the groove. Press the wood against the boot edge and with a small screw driver, push the wire loops off the nails. This makes the wire loop replacement so easy, I am going to keep the little streatching jig with the machine. With the outter boot edge released, it is a snap to clean the area around the front of the outter drum. This is one of the areas that builds up the gunk that makes these washers smell. With replacing the boot clamp this easy, I am going to make this job part of the regular mantanience of this washer. Good luck with your job.
Posted on Jun 11, 2013
  • 5,911 Answers
This is often a very tricky process. The easiest way I know how to get the inner spring back in place is to use two sets of hands and work through the door and through the bottom panel as well. Follow these steps:
1. Remove the lower panel under the door.
2. One person reach through the door opening and insert the spring in the bellow groove, starting at the top.
3. Work the spring around to the 3 and 9 o'clock positions and hold in place by keeping your fingers on the spring in the groove.
4. Have a second person, laying on their back, reach through the bottom panel and grab the lower half of the spring on each side with both hands.
5. While the first person holds the upper portion in place, the second person pulls straight down and works the remaining portion of the spring in place.
This is the best way, I have been able to accomplish this. Make sure you use a type of applaince adhesive to reseat the outer portion of the bellow to the door frame if this is the glue on type. If you have questions, or require additional assistance, please let me know.
Posted on Jan 16, 2009
Leaks from the front
If you have a leaking FRONT LOADER, the following link explains how to access and inspect your washer for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of the cases with front loaders, the door bellow begins to leak. A routine inspection of the seal perimeter will tell you if there are any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Follow the tips in the links provided and make sure you inspect all the drain hoses, drain pump cover and tub seals as well.
If you have any questions, please post back and let me know. I hope you find this information helpful.
May 05, 2010 | Kenmore HE2 Plus Front Load Washer
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Jan 31, 2010 | Kenmore HE2 Plus Front Load Washer
I opened the door on my he2 plus 1104751 and a large retain type wire with a spring was there. I assume this goes around the tub seal to hold it on tight?
Yes, it is used to secure the bellows (door side) of the gasket to the cabinet. If the loop is still intact, you can use a pair of needle nose pliers to reinstall the retaining wire onto the gasket.
If the wire loop is broken, you'll want to get a replacement ASAP to prevent leaking and to prevent damaging the gasket too. They're available from searspartsdirect.com or you can check for a local parts supplier if you wish.
Hope you find this Very Helpful and best regards!
Oct 09, 2009 | Kenmore HE2 Plus Front Load Washer
Door switch schematics for Kenmore HE2 Plus front loader needed
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 10, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 won't finish spin cycle
1. Unplug washer.
Feb 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 door bellow
he 2 are a little similar to all H E washer ,, it has spring clamps (2) remove and install them same way
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Bellow Replacement
Make sure the drain holes are clear in the bottom of the bellow. Also, make sure the bellow is aligned properly. There should have been an alignment arrow at the 12 o'clock position. Hope this helps.
Aug 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
518 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
