I've got a APC Smart UPS 3000 (SUA3000RMI2U). I've changed the batteries and the unit still won't carry the load of a single Dell Poweredge 2950 power pack. The batteries show as being fully charged and when I do a test all lights show up on the overload, the system makes the overloaded sound then I get 3 of the 5 red lights on the battery side that comes on and the unit switches off. Any Thoughts?
Did you run this test without AC input?
Also what happens when you cut off the AC mains without any load connected to it? Will the UPS continue to run or does it switch off as well?
It works fine with low load on it like a standard desktop, monitor, 24port switch. The minute I put just one poweredge 2950 server (one PSU) on it it falls over. I've run the batteries flat using la small load and then I've let the batteries charge up again. Out of curiosity, the load lights on the left don't light up until the power is lost from the UPS?
Oh . . . yes, it runs fine with no AC input ... just with 'medium' load it falls over
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
SOURCE: APC BR800 Overload light with beeps
Your main control board is defective, you need a new unit.
SOURCE: SMART UPS APC 3000
let the ups be turned on just charging the batteries, u can have the voltage but the batteries still not fully charged. good luck
SOURCE: hi my APC 1500VA smart UPS show overload
Contact APC Customer Service. They will help you resolve this. If unit is still under warranty they will replace it. There is nothing you can do to repair anything yourself. Sorry ... try calling 1-800-555-2725800-555-2725 for support from APC
