Does the blower motor run? Is it that you get no heat? check a few things. does both the heater core hoses get hot.? and it can also be a blend door motor
CarGurus2001 Mazda Tribute 3.0 Wont Start. out shopping one ... 0. Report. rebel54 asked a2005 Mazda Tribute i Maintenance & Repair question about a month ago ...
May 22, 2007 - I have a 2002 Mazda Tribute V6. On Sunday it wouldn't start. ... 2005Tribute won't start! rizakag, Mazda Tribute, 4, 03-27-2006 09:29 AM ...
Why does my fuse in my 2005 mazda tribute keeps blowing ...www.cargurus.com > Questions > Mazda > TributeCarGurusSep 4, 2014 - Why does my fuse in my 2005 mazda tribute keeps blowing when I try to switch gears?Electrical problem - 2004 Mazda Tribute - RepairPalrepairpal.com > Questions > Mazda > Tribute > 2004 Mazda TributeApr 5, 2011 - Electrical problem on 2004 Mazda Tribute ... meter on the battery cable note the battery draw then remove fuses one at a ... 2005 Mazda Tribute.2005 Mazda Tribute, Fuse #3 Blows, No Tail Lightswww.sparkys-answers.com/.../2005-mazda-tribute-fuse-3-blows-no-tail.h...
Could be the relay for the lowbeams is faulty, if your DRL's are your lowbeams, then your DRL Unit could be bad. Also did you blow a fuse cuz a random surge could blow the fuse
Two things: If there is a stickiness or sweet smell to the water, your heater core may be leaking.
If this is just a summer thing, your a/c evaporator drain tube my be blocked/clogged or leaking inside the vehicle.
From Haynes Repair Manual #36071, Ford Ranger Pickups 1993 - 2005 and Mazda Pickups 1994-2005 B2300, B2500, B3000, B4000: (1)Disarm the airbag system; (2)allow the cooling system to completely cool down; (3)using a thick cloth for protection, turn the radiator filler cap to the first stop; (4)step back and let the pressure release; (5)once the pressure has been released, completely drain the cooling system; (6) working within the engine compartment, loosen the ****,ps on the heater hoses at the engine compartment side of the firewall, twist the hoses and carefully sepseparate them from the heater core tubes; (7)plug or cap the heater core tubes to prevent coolant from spilling into the passenger compartment when the heater core is removed; (8)place a plastic sheet on the floor of the vehicle to prevent stains if the coolant spills; (9)remove the instrument panel; (10)remove the PCM heat sink and ground strap; (11)remove the heater plenum chamber; (12)separate the heater core from the heater plenum chamber; (13)installation is the reverse of the removal with the following additions; (a)fill the cooling system; (b)run the engine, check for leaks and test the heater
