Question about Quantum Guardian 4400 120 GB Hard Drive Array
Quantum Guardian 4400 NAS - IP unknown
I have a Quantum Guardian NAS that was left by a previous employee. I do not know the IP address, device "name" or anything aout it to be able to communicate with it on my network.
How do I log onto it over the network please?
2 Suggested Answers
SOURCE: qwanum guardian 4400 server type 480 GB
I tried hyperterminal it works very good and i see my computer starting up it works very good.
The problems i see now are that there is no Guardian OS installed on the the system is looking for an OS he cannot find it and the system hangs,
Do someone know how i can get Guardian OS to install?
Posted on Dec 31, 2007
NAS Disconnecting from Network
I hope the brothers who has a program Printer Definition "murtec mfx 2010" Windows 7 download link here Vlada graciously
Mar 10, 2014 | LaCie d2 Network v.2 - 3TB
DHCP Server Conflict
Login into tape library console using web browser and disable DHCP and provide Static IP .
Mar 30, 2012 | Quantum Technology SCALAR I80 LIB 1XLTO-5...
Windows vista is not detecting lacie network space 2 i am trying to install a lacie network space 2 (1T) on a home network. i use windows vista icw avg free virus software. i installed the latest...
In your office network, for sure, you have a DHCP server who gave the IP addresses to all devices for that network and this seems to be the reason for why you could see your NAS. On home, you also need a DHCP server. You don't say anything about you home network. The best idea is to just make a temporary network with 2 devices: your computer and your NAS by connecting the NAS directly to your computer's network adapter, set the IPV4 IP for that adapter to the same class addresses as your NAS was set by default (usually NAS had "192.168.x.y" where "x" could be 0, 1 or 2 "y" could be any value between 1 and 254, but mostly, 1) and try to access it via http to manage him (need a user name and a password). For NAS default address and username and password, consult NAS user manual. Access it with from your preferred browser using: \\192.168.x.y
Once you gain the control, cut off his DHCP service and tell him to accept the IP address from the network defined DHCP. (btw: one normal DHCP server is allowed on one network! Cascaded DHCP also is allowed, but it's a little bit complicated)
Jun 25, 2011 | LaCie Space 2 (301515EK) 1000 GB Network...
I had to replace my router and I now cannot see the dlink enclosure. I wanted to get the IP so I can reconfigure the IP address but like I said I cannot seem to get the device to show up on my belkin...
You can try a couple of things, easy thing is to reset the NAS server by unplugging it and allowing it release its leased IP address, assuming that it is setup for DHCP. Once this is reset it should grab another IP address. If you remenber setting it up for a static IP, then you could do a google search for an IP scanner or find one that you are comfortable with download and install look for device on your network that will give you your IP to the NAS server. Good luck
Nov 28, 2010 | D-Link DNS-321 Network Attached Storage...
My Black Armor NAS keep changing its IP address and can't be accessed most of the time on the network. Hw can i fix this
Configure your network's DHCP-server to *ALWAYS* give the *SAME* IP-address to the NAS -- use the (unique) MAC-address of the NAS's network-adapter to assign a "static" or "fixed" IP-address to the NAS.
Jul 27, 2010 | Computers & Internet
I need to reset the mitel 5212 IPphone passcode as the previous employee has left can you advise how I do this please as I need to set up voicemail
Hello...if u have access on mitel system then u can goto user configuration form then select extension# u want to edit...from there u can even delete the mac address and more..hope it helps
Nov 04, 2009 | Mitel 5212 IP Phone
I've bought the Sumvision SATA net-box NAS enclosure, installed hard drive as described, but I cannot see the web interface for setting up the device. Manual is in very bad english and suggest allocating...
There's a discussion about some problems relating to this enclosure at and you may be able to get some help from the contributors there.
Jun 27, 2009 | Computers & Internet
Qwanum guardian 4400 server type 480 GB
i had the same problem with a NAS device. I opened it up and removed the battery and all power sources. I then waited a few minutes and put everything back. The system reset to factory defaults. It now works for me.
I later found out the unit has three ethernet ports. and if the settings are incorrect then the "Gateway" is not found. You may want to connect it directly to a router and see if it gets an ip.
I've tried hyperterminal and it didnt work. There are too many parameters that can interefere.
Dec 24, 2007 | Quantum Guardian 4400 120 GB Hard Drive...
Can't assign ip configuration to NAS 208
Probably the NAS got the same IP address of the router/switch. Something like Try changing your router default IP address to Look for the NAS now.
Dec 22, 2007 | Computers & Internet
Help please to restore the failed raid
Well if your data is gone at this point, you mines well just proceed with rebuilding a new RAID 5 set with your replacement drive. Even if one drive fails in a RAID 5 set, your logical drive should still be accessible. Goodluck.
Jun 14, 2007 | Quantum Guardian 4400 120 GB Hard Drive...
Quantum Guardian 4400 120 GB Hard Drive Array Logo
216 people viewed this question
Top Quantum Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
