Question about LG LMVM1945 Microwave Oven
LG microwave oven
Our LG microwave oven (LMVM1945SB model) has been turning itself on. It appears that it is just the turn table on; not the microwave itself. It happens quite often. Customer Service does not help.
  • 7 more comments
  • Teri Wagner Jun 14, 2007
    no this issue has not been fixed. I've heard this is a known defect, but LG customer service doesn't tell me. Does anyone else have this problem?
  • elliswyatt Mar 27, 2008
    My microwave is doing the same thing. It's all the time though. Anytime the microwave door is closed the turntable is turning.
    I don't remember this happening prior to two weeks ago, but I may have just not noticed (new house). Is there some easy way to diagnose what's causing this problem? I'd like to get it to stop what it's doing as it's quite annoying.
  • Anonymous Dec 31, 2008
    My problem is that the microwave will start itself while cooking on the stove top. Model # lmv1680. Can anyone offer assistance with this problem?
    Thank you.
  • Anonymous Mar 13, 2014
    The unit turned itself on....twice so far. Then the buttons wouldn't work to turn it off. I had to open the door to get it to stop. Unplugged it, started over. Now some buttons work.
    I'm guessing new main board is needed.
  • Anonymous Mar 23, 2014
    The oven part works but the microwave does not. The light comes on and the table turns but no heat
    No heat but turn table and light works. The oven part is ok, but the microwave does not
    Lg model number is lmvm1945sb what does a F-9 mean
  • Anonymous Mar 24, 2014
    Turn off beeping
    Rotating ring for model LMS-1221SS Microwave oven
  • LG Master
  • 9,098 Answers
It's usually a bad door switch or a broken door switch mount. Once in a while it's due to a board problem. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jun 15, 2007
My microwave oven turns on but does not heat the turn table turns but no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Aug 04, 2011 | LG 2.2 Cu. Ft. Over-the-Range Microwave -...
COOKWORKS MODEL EM717CKL THE TURNTABLE WILL NOT TURN WHEN SWITCHED ON
The Turn Table motor will need to be replaced, this appears to be a common problem in the microwave ovens. I recommend a suitable technician because there are dangerous high voltage present.
Jan 15, 2011 | Microwave Ovens
I have LG MS-3444DPS Intellowave Microwave oven. Turntable has had intermittent high pitch squeal and also thumping noise as turn table turns. Turn table has also been very jerky since new. What is the fix...
If you were to take the turntable coaster out and wash it in hot washing up water paying attention to the wheel surfaces, I think that will fix your problem as I suspect the wheels are uneven with deposits stuck to at least one.
Hope this helps.
Nov 27, 2010 | LG Microwave Ovens
Turn table will not turn .
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 29, 2010 | LG LMV1680ST Microwave Oven
Microwave won't heat, appears to be on.
heatman101
jhdfs
Feb 26, 2010 | GE JE1540 Microwave Oven
I have the part I need, but I need to disassemble the door to install it. I don't see a way to do that...Model LMVM1945SB
Remove the outer cover from the microwave oven to gain access to the door hinges. With the door off, and lying face down on the table, carefully pop-or-pry the plastic door seal off the inside. Presto, access.
Nov 12, 2009 | LG LMVM1945 Microwave Oven
Touch pad doesn't work LMVM1945SB Microwave
that would be for a technician only........ electronic parts of that type are not generally self repair nor readily available
Sep 20, 2009 | LG LMVM1935 Convection/Microwave Oven
Microwave Oven model #JVm1850wd002 turn table does not operate or
Take off the case. You'll see two prongs on the door. If they are out of adjustment.And don't trip the contacts. nothing will work. Theres nothing mech on the turntable, the micowaves make it turn. Just make sure it turns freely,and is clean.
Dec 29, 2008 | GE Microwave Ovens
Light bulb burns hole in the plastic cover
Same issue here. I just bought 4 covers from RepairClinic.com for $5.50 US each. I shipped them to my PO Box in Buffalo for an extra $6 bucks. Part number was 1206433
Hope this helps
John
Dec 23, 2007 | LG LMVM1945 Microwave Oven
LG LMVM1945 Microwave Oven Logo
488 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
