Question about Tally Line Matrix T6215 Printer
Genicom Tally T6215 not printing on edges.
Having issues even when troubleshooting with adjustments print will fade in and out on the left and right edges.
  • leerobb Feb 04, 2009
    Ordinarily that would work. I tried that and the edges were still fading in and out. I ended up putting to much tension on the plated for print that it jammed and had to go back the next day for a service call. I replaced the ribbon and quaility was better that ever and printing to the edges again. Thanks for your efforts.
    New Friend:
  • 114 Answers
Adjust the platen screw manualy.
Posted on Feb 01, 2009
Ribbon fault error
First of all sorry for the problem.
It seems to be a logic card problem . Kindly contact with lipi for replacement of the logic card.
Aug 16, 2012 | Tally T6215 Matrix Printer
Why can't I print through a Tally T5040 printer?
Tally genicom 5040 passbook printerre download the drivers and make sure you have a good connection (USB )
Mar 21, 2012 | Office Equipment & Supplies
Tally t6215 is printing continuously, one line a page. how do i make it print normally?
I would suspect this is happening because the system printing to the T6215 is sending only Line Feed Commands and not Carriage Returns. Access the menu on the T6215 and enable the AUTO CR function. This will cause the printer to append a Carriage Return each time it sees a Line Feed, this should resolve the issue.
Dec 22, 2010 | Tally T6215 Matrix Printer
Genicom 4440 is 15 years old and is used to print invoices with bar codes. The bar codes are not passing USPS regs. They are curved and were not like that years ago. Can the print head be cleaned or...
Yes to both questions. This printer has 3 print modules. you can try swapping the right side for the left side module or vise versa and see if the problem changes. if it does then you should replace the bad module.
Jan 31, 2010 | Tally Genicom 4440 Printer
Need to set the head gap on a Genicom 3870. Lost my manual.
If it has a manual adjust, open the top cover and on the right side will be a slide for different head adjustments, it wll be numbered 1-6, 6 being right against the paper which causes smears. Move to around 3. If it has auto adjust (you can tell this when you power up the display will show "adjusting gap" then press off line, the press program, move to head adjust, press enter, press enter again then use the arrows up and down to move to your type of printing, 2part, 3 part ect.
Mar 13, 2009 | Tally Genicom 3810S Printer
GenicomTally T6215 line printer not printing on edges
If your still having problems? 1st make sure the gap is not to tight(cause the to ribbon to drag up with paper). 2nd While printing in test mode, carefully lift up or push down on the ribbon where it comes out or where it goes back in the catridge. After doing the 2nd you should see the exact same thing as will stop printing on right and left edges. Remove the ribbon, their are 2 philip screw on the left and right side of the ribbon deck, loosen them(they will not come all the way out, held on by clips) lift the rbbon deck up and reseat it... tighten the screws back down. last you may have some bad ribbons...
Jan 14, 2009 | Tally Line Matrix T6215 Printer
Tally t2250problom
go in setup ,check paper ,inside size ,width,
select one that u want and save it & test
Dec 06, 2007 | Tally T2250 Matrix Printer
Tally printer form feeding continually on its own
When was the last time it was services? It may be nothing more than a dirty paper sensor. Also, some Tally printer sensors require adjusting, it may be a simple matter of adjusting a sensor setting. That would require a technician with the manual and settings chart. Let me know how it goes!
May 01, 2007 | Tally T6215 Matrix Printer
Tally Line Matrix T6215 Printer Logo
201 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
