Question about Sharp AR-5316 Advanced Digital Imager Copier
L6 sub 10
Sharp ar 5316 .it have code L6 sub 10
    President:
  • Sharp Master
  • 990 Answers
Hello sir; I'm not sure the error code can be reset or not but we can give it a try, the easiest way just turn power on and off if don't work follow following steps;
1, press "#", "interupt" "c" "interupt"
2, enter 14 then press start.
Posted on Jan 14, 2009
Error L6-10 sharp AR5127 Problim i dont know I
You forget to connect the laser cable to main-board.
Jan 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
TANKS, FOR YOU HELP, I HAVE PROBLEM WITH SHARP AR-5316 IS COD-L6 10
this error is a Polygon motor lock. the polygon motor drives the mirror in the laser unit. You will have to replace the laser unit or the motor/mirror unit.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Error code sharp 5127
go to percision roller in phx arizona you can get all sharp service manuels i have alos seen them on ebay?
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Gunawan
Hi Gunawan,
The error 'L6' is usually an indication of problems with the Laser Unit in the copier.
Unfortunately the unit will have to be replaced and can only be done by trained personnel.
Contact your closest Sharp Dealer for assistance.
Regards
Gavin
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
E-7 sub code 10
Check connection of the ccd cable to the ccd and the pcu board, if all good the you have problems. try reseting the m/c first
Aug 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316
L6 is a fault with the laser.
To be more specific there is a set of mirrors mounted to a motor inside the laser assembly. The machine is detecting the motor is not running.
Most likely the laser itself will have to be repalced, it is also possible the main processor has failed and is not seeing the motor running.
There is the possibility of a loose connector, but that is the least likely.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
473 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
