Question about IBM Infoprint 1532 Laser Printer
Printer not catching paper, but suggesting a jam
This has been happening for a about 8 or more hrs. now. What can I do to get the paper to print reports here at work?
printer not catching paper, but suggesting a jam - s.gif document.tlSearch.tx.value=unescape("") s.gif s.gif Even if it's not the same model this should give you a good idea of what needs doing... hope it helps you as much as it did to me
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl12422#A9
13.02, 13.05, 13.20, 13.21 JAM IN TOP COVER AREA
Rgds,
Gudrance
Posted on Jan 14, 2009
Photo printing errors
This is not the fault of printer. Choose those type of photo paper, whose thickness is equal to executive bond paper. This type of printer do not catch the thick photo quality paper
Apr 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Hi :) I'm trying to print on my Canon PIxma- mp480 to no avail
Hello
This can be due to a feeder wrong setting on the printer or on your PC: your printer tries to take paper from the back feeder, whereas your paper is on the front feeder....
try to check these settings in your PC and on your printer, and retry to print, hoping this helps
Jul 29, 2009 | Canon Pixma MP480 All-In-One InkJet...
Paper jamed
Sounds like the fuser is causing the jam. Anything from a dislocated pic finger to other paper debry can be causing these types of jams.
If you open the back door, will the page exit the printer fine of does it still jam?
If it still jams the fuser is definatly the problem. If it dosen't, then it might be the delivery assembly causing the jam.
You might be able to see where the jam is happening if you print something and watch it though the back to see where the paper catches and jams.
Nov 19, 2008 | Brother HL-2040 Laser Printer
Paper jam with card stock paper
Try Getting a PM kit to replace all the rollers.
Nov 13, 2008 | HP LaserJet 2550Ln Printer
E3 on LED paperwill not feed
What you want to do is remove all paper, the prepare to run a print test page or print a blank sheet from some program, any program. Just be ready to do this.
Now, find a magazine cover or index card stock, something firm. Cut this magazine cover to the same width as regular paper 8 1/2 in the US or A4 in Eurpoe.
Now, when you start the print job, push the magazine cover or index stock through while its printing. Apply pressure it the key, to getting the thicker paper through.
This will clear the sensors in the printer and remove the error message.
Why did this happen? In the printer, there are numerous sensors to identify jammed paper. This can happen for the strangest reasons. By pushing thicker paper through while feeding paper by running a print job, the thicker paper forces the sensors back to their original position.
Regards,
Worldvet
Nov 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jammed in printer - need to remove paper tray
1 This works from HP help link in error message:
Turn off the HP All-in-One.
2 Press in the tab on the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. icon_caution_color.gif Caution Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Jul 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer will not catch paper in tray
The rollers need to be clean or replaced.
Feb 04, 2008 | Dell M5200n Laser Printer
Canon Pixma ip 2200
send me printer driver canon ip 2200
Nov 12, 2007 | Canon PIXMA iP2200 InkJet Photo Printer
Paper doesn't advance through the printer
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
Aug 25, 2007 | Lexmark Z31 InkJet Printer
IBM Infoprint 1532 Laser Printer Logo
198 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
