Question about Tally Line Matrix T6215 Printer
GenicomTally T6215 line printer not printing on edges
This appears to work at times and not at times as you troubleshoot with the adjustments. It will print then it will stop printing on right and left edges.
  • leerobb Jan 15, 2009
    Issue solved...Installed new ribbon cartrige. Book shows to do a hammer calibration also.
    Scholar:
  • 34 Answers
If your still having problems? 1st make sure the gap is not to tight(cause the to ribbon to drag up with paper). 2nd While printing in test mode, carefully lift up or push down on the ribbon where it comes out or where it goes back in the catridge. After doing the 2nd you should see the exact same thing as will stop printing on right and left edges. Remove the ribbon, their are 2 philip screw on the left and right side of the ribbon deck, loosen them(they will not come all the way out, held on by clips) lift the rbbon deck up and reseat it... tighten the screws back down. last you may have some bad ribbons...
Posted on May 12, 2009
T6215 stop to print at 2000 lines printing
That suggests it has the wrong driver or either the printer or the computer needs more memory
Aug 04, 2016 | Tally T6215 Matrix Printer
It is printing and after a time it jump and skip printing from the require area
ensure you have the correct driver for this printer installed.
run any built in test to ensure the printer is working correctly.
I hope this was useful.
May 23, 2011 | Tally T6215 Matrix Printer
Am running windows7 and when i try to add a form with 21" width and 30.50" height my form is not added.
The form width you are trying to create is wider than the T6215 is able to print on. The maximum page width that you can print is 13.6 inches, if you try to create a custom size paper wider than 13.6" Windows will not show you this form within the T6215 printer driver. As you can not physically print 21" wide you do not need to define a paper size this wide. Simply create a paper size which reflects the maximum print width or 13.6" You will then be able to print the maximum width the T6215 is capable of and also see this form in the printer driver.
Jan 03, 2011 | Tally T6215 Matrix Printer
Tally t6215 is printing continuously, one line a page. how do i make it print normally?
I would suspect this is happening because the system printing to the T6215 is sending only Line Feed Commands and not Carriage Returns. Access the menu on the T6215 and enable the AUTO CR function. This will cause the printer to append a Carriage Return each time it sees a Line Feed, this should resolve the issue.
Dec 22, 2010 | Tally T6215 Matrix Printer
Pin not firing
It is hardware problem which is very difficult it is better if you can call to the service engineer.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Tally Line Matrix T6215 Printer
Cant print from pc
I was using a parralell port i ended up removing the network card and that solved my problem
Aug 11, 2008 | Tally Line Matrix T6215 Printer
Tally printer form feeding continually on its own
When was the last time it was services? It may be nothing more than a dirty paper sensor. Also, some Tally printer sensors require adjusting, it may be a simple matter of adjusting a sensor setting. That would require a technician with the manual and settings chart. Let me know how it goes!
May 01, 2007 | Tally T6215 Matrix Printer
Tally Line Matrix T6215 Printer Logo
147 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
