Question about Toshiba e-Studio 35 Copier
Changing the Developer on a Toshiba E-Studio28
Just looking for some guidance, or technical diagrams on how to change the developer on a Toshiba E-Studio 28 copier. Any help appreciated.
  • 4 Answers
Just take out the top cover of the unit, dispose all the used developer material and next fill it with new, after mounting back on the machine do code 200 of the service mode 05, that's all
Posted on Oct 01, 2007
  • 186 Answers
If you are not a technician I would not even attempt this!
Posted on Jun 16, 2007
My thoshiba e-studio 352 giving an error "latch the developer unit". Please help to resolve this issue. Thanks Roy Robinson
I think the cable is not connected properly on the developer unit...Open front cover, take out the waste toner box, and u will see the connector.
Oct 02, 2013 | Toshiba e-Studio 350 Copier
Add developer to dp-262
YOU DONT ADD DEVELOPER, YOU CHANGE IT LIKE CHANGING THE OIL IN YOUR CAR. THIS REALLY NEEDS TO BE DONE BY A TECHNICIAN BECAUSE ONCE YOU CHANGE THE DEVELOPER YOU NEED TO RESET THE COUNTER FOR IT AND DO A DENSITY ADJUSTMENT WHICH REQUIRES A SERVICE MANUAL. GOOD LUCK !
May 04, 2012 | Panasonic WORKiO DP-C262 Printer
Where we can buy toshiba studio 230 developer?
677864645f7a396c54674d71464b78424b4677-100x100-0-0.jpg Toshiba E-STUDIO 163 202l Developer Black
New Genuine Original D2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $88.21ExtraMileToner
at
GenuineBrandSupplies.com
New Genuine Original D-2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $65.33
Oct 21, 2011 | Toshiba e-Studio163 Copier
Sc990 on Aficio 1035
Software performance error The software attempted to perform an unexpected operation.
Software defective Internal parameter incorrect
Insufficient working memory When this SC occurs, the file name, address, and data will be stored in NVRAM. This information can be
checked by using SP7-403. Note the above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
Ok, that's the "OFFICIAL" meaning, in reality, EVERY TIME I'v had this, it took a PM or at least a Developer change and a good idea to replace the Drum and Drum Cleaning Blade too, Be sure and run the setups too.
Enter the service mode.
Clear modes, 1,0,7 and hold down the Clear/Stop key. Press COPY SP on the display and enter the following info.
SP2001 = 1480V
SP2201 = 600V
SP2801 (after new developer is installed)
SP2805 (after new drum and developer is installed)
SP3001-2 (after cleaning the ID sensor and/or replacing the drum)
SP7804
SP7807
Good luck.
Sep 04, 2009 | Ricoh Aficio 1035 Copier
My Toshiba E-studio28 Copier stopped working
its sounds like the developer is dry (out of toner) try opening and closing the front cover multiple times (no less than 5x) if it is still on you will have to call toshiba service provider to correct issue
Apr 29, 2009 | Office Equipment & Supplies
Developer leakage while copying
after replace  developer you dont turn round the developer wheel left side. only right side.try this take out the developer and after re fill in to the developer unit. and u change the main charger unit also.
Feb 06, 2009 | Toshiba e-Studio 161 Copier Copier
Toshiba 2060 copier. What happens when developer needs changing?
Hello sir; the developer on this model is requested every 80,000 copys need to change, if don't change the image will be fade.
Jan 05, 2009 | Toshiba Estudio 200L Copier
How to change developer on Toshiba 2060 copier?
Changing the developer is a procedure for service technicians to do.  You might want to ask that question on copytechnet.com.  There are Toshiba service technicians on that can help you with that.
Sep 13, 2008 | Toshiba 2060 Copier
Changing Developer on E-Studio 150
The developer you need to purchase is 1620 , and the drum unit also the 1620, you can see this number in the toner catridge itself. or in the toner catridge box. Regd. the 161 you need to purchase the products name 1620 number and the concerned part like developer, drum, toner, some gears etc.
Aug 19, 2008 | Toshiba e-Studio 161 Copier Copier
Sharp ARC270, washed out color
I would have to say that they did it wrong or that you have a transfer or drum charge problem
Jul 08, 2008 | Sharp AR-C270 Color Copier
190 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
