Question about Yahoo Messenger
Yahoo messenger 9 on vista
I cannot install yahoo messenger 9 on vista even with firewall and user account control switched off. pls help. thanks!
  • Anonymous Feb 21, 2009
    baal hain sala
81003003 problem in Yahoo
Posted on Sep 24, 2009
  • 827 Answers
Yahoo! Messenger for Vista can be downloaded from Yahoo! site, but it’s a small initial setup loader that also include annoying features such as Yahoo! Toolbar. To directly download the standalone installer package which can also be used for offline installation, use the following link.
ymsgr_vista_setup.2008.01.11.428_us.exe
Hope this helps
Chris (ziraffa)
Posted on Jan 14, 2009
When i download yahoo messenger 10 it says, "Yahoo messenger is unable to download files needed for installation. please check firewall settings and retry installation."
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
Make sure your IE is up to date (IE 8) - even if you run another browser as default. IE is coded with Yahoo Messenger
If you do use another browser - check that IE is not set to 'Work Offline' under 'Tools' and has a red X through globe allowing it Internet access
The problem is probably due to a mal-function of the uninstall software.The Yahoo Messenger uninstall software is notorious for leaving files and fragments behind creating conflicts with the incoming software
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall the old Yahoo Messenger program from the Control Panel and failed to back it up with a visit to the 'C' drive, you may have old software conflicting with the incoming software trying to share the same folder. These conflicts will be enough for the firewall to hoist a red flag
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start
Sep 22, 2010 | Yahoo Messenger
Cannot log on to Yahoo, error messaGE 81003005
i too hate vista
neway it does not affect hte log on of yahoo ......
did u check ur cookie settings.......
Oct 13, 2008 | Computers & Internet
Cannot download ym it shows check firewall setting
You can disable your firewall setting when its hard trying to download Yahoo Messenger.
How to do that? Try this:
1. On your windows, click Start.
2. Click Control Panel
3. Double click Windows Firewall
4.On the General tab, select OFF(not recommended) and click OK
That's it! Your firewall setting is disabled and you can download yahoo messenger without being stopped by a message error.
If you have successfully download Yahoo messenger by disabling windows firewall and still cannot sign-in, you will be needing some tips on how to solve connection issues for Yahoo Messenger. Check this helpful tips http://www.fixya.com/support/r5025589-easiest_way_solve_yahoo_messenger
Please comeback and give me some ratings if this one help you.
Thank You for using Fixya!
Jun 06, 2010 | Yahoo Messenger
Firewall stops me using yahoo messenger
Uninstall or disable any security software running on your computer. Try restarting your computer in safe mode with networking and then installing. If all of the above doesn't works and still you were getting message for firewall then either disable your Router's firewall by opening Router's page or Bypass router for a while and connect directly to Modem and then Install.
May 23, 2010 | Yahoo Messenger
Unable to run messenger
Its a pity you chose to re-install - a simple toggle of the connections from 'Direct' to 'Proxy' was probably all you needed.
As for your current installation problem:-
You do not need to adjust your firewall for uploading Messenger
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
If you have Vista you may be denied being able to delete folders - in this case you will have to disable the 'User Account Control'
Start > Control Panel (Home) > User Accounts and Family Safety > Add or remove user accounts > Continue > Go to the main User Account Page > Turn User Account Control On or Off > Continue > Uncheck control box > OK
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Re-start your computer
Download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
May 07, 2010 | Yahoo Messenger
My yahoo messenger account has been locked
Do you have windows vista?
Yahoo messenger 9, is BETA and very buggy.. Uninstall this program.
Then
Find and install an older version of messenger. Yahoo messenger 8.1 will work.
http://www.soft32.com/download_30.html
Another big problem is with the latest update for Flash Player
Flash player 10 Does have conflicts and is causing things to not load or just crash upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel, then download the older version.
Sep 29, 2009 | Yahoo Messenger
I need to get my contacts back
Your contacts list is stored online, you can change versions and contacts transfer.Not sure what you mean by disconnected ( from what? yahoo,messenger,) Do this,
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
Dec 10, 2008 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Dec 09, 2008 | Yahoo Messenger
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
Yahoo Messenger Logo
510 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
