Question about Mission 78C Center Speaker
Mission 78C Centre - no bass
After 7 years service my 78C centre speaker has suddenly stopped working. You can still hear a tinny output but no bass and no real volume. Wonder if the midrange crossover has failed - as it has 3 tweeters and 2 midrange speakers seems highly unlikley that driver failure is the problem ? I have checked its not the amp. [Note I posted this in the mission 77 area by mistake]
  • 2 more comments
  • john62784 Mar 19, 2009
    I seem to have the same problem, no base and very tinny. As I have the speaker biwired I unplugged the base and found the sound to still be tinny. when I plugged the cables into the base their was no sound so I can only conclude that the crossover has failed as I can't believe both drivers would go at the same time. Time for it to go to a repair shop for proper testing.
  • nickgillies Mar 21, 2009
    Same problem - also intermittent loss of bass on my two front speakers (Mission 780). Changed my Amp thinking that was the problem but no joy. Speakers sound tinny. My speakers are Bi-wired and Amp is Denon 3803. All speakers worked fine for three to four years. My system is used only occasionally.
  • sted11 May 07, 2009
    Same for me, not intermittent.
    I had the same conclusion: it is a crossover issue.
    Did you try to repair it by yourself?
  • erithan Dec 18, 2009
    I've got the same problem with my Mission 780s. Does anyone know how to fix the crossover?
3 Suggested Answers
Icebassman 5
  • 57 Answers
SOURCE: Mission 780s (from early 1990s) tweeter gone?
Hi there.
Do you have the make and number on the back of the magnet?
Check if the tweeter is at all available on the net!
To have it repaired is also an option.
Posted on Nov 05, 2009
  • 352 Answers
SOURCE: Mission 78C Centre Speaker Only sound is coming
The most likely cause is the Crossover unit inside the speaker has failed, It is possible that a wire has come loose also inside the unit. The Crossover unit is what separates the High Frequency sounds from the Mid and Bass Frequencies, if this unit has failed or a wire has come loose then it will cause your problem.
By Unscrewing one of the outer speakers you should be able to see the wiring. trace the two wires from these outer speakers back to there first join, make sure it is connected correctly.
There should be two wires coming into the back of the box, then directly to the crossover unit. from this crossover wires to each individual speaker.
I hope this helps your problem Regards GM
Posted on May 28, 2011
Why is there no bass from my speakers when plugged into laptop?
Could be something wrong with the output from laptop.Try wiggling the jack in the connector while music is playing to see if there's any change.
May 21, 2012 | Logitech Speaker System Z623
I have this mission 782 for many years! It happen
It's bi-wireable (BUY-wire). Did it occur to you that may be a factor if you're using it that way? The jumpers (or lack thereof) on the back allow or disallow the amp(s) to affect all the drivers. You can tie any amp to one or the other pair of binding posts to test them.
Sep 19, 2011 | Mission 782 Main / Stereo Speaker
Recently one of my mission 782 side bass driver has no sound, is it dead? Do you have any idea where i can get the driver to replace? and is it difficult to replace by myself?
Drivers are easy to replace in most speaker systems. There will be 'spade' type push-on connectors to the drivers. Here are contact details for the Mission service centre in the UK: They should be able to supply you with a replacement.
I cannot seem to get the driver working on my new computer which has windows 7 currently. Are the two compatible?
Are we looking at this same computers? Since when do you require drivers for speakers?!? Speakers are dumb devices (yes, this is correct name for passive computer devices) and do not require any drivers in any computer or operating system with sound capability! Computer speakers are compatible with any copmuter in the world and any operating system which generate sound!
These speakers are qualified as 5.1, that meant that these speakers will have front bass, front centre speaker, front left and right speaker and rear left and right speaker, in total six speakers.
Please follow this advice and you will have joy of surround sound.
1. Mount your subwoofer in front centre, below your knee level at the distance of about 2 of your hights
2. Mount your centre speaker in the centre on your head/hight level or slightly above at same distance as subwoofer or slightly closer.
3. Mount left front speaker about 45degree from your centre line to the left and right same distance to your right, on the level of your head while you are listening to the music, distance from you slightly closer (about 1/2 your hight) than your centre speaker.
4. Mount your rear left and right speakers at same or slightly greater distance as front left and right speaker. these should be at same or slightly higher level as front speakers.
5. Triple 3.5mm jack is going to your computer output and your speakers (incidently, your subwoofer servers as junction box, amplifier and mixer).
6. Connect speakers to they respective jacks.
7. Turn power on speakers all way down
8. Connect power to the speakers and switch it on
9. Play some music on your computer, output on full, music recommended will be some classic, like bach or similar
10. Put your hand in front of subwoofer and turn bass till you feel vibration
11. Turn sound till you hear it well
12. Turn sound on the computer down till about 70% - 80%
13. Turn on sound on your speakers till desired level and enjoy the experience!
If you have still some problems, these can be then related to the drivers installed on your computer, please check therefore what motherboard do you have, if there is proper sound drivers installed. If not, go to the site of our motherboard/sound card manufacturer and install relevant drivers.
Please do not hesitate to ask me if you have any addtional problem related to this particular issue.
Aug 06, 2010 | Creative Labs Inspire T5400 Computer...
Centre Channel speaker has stopped working
connect any speaker instead of center speaker if you get the same result you will have a problem in amp itself if the problem fixed change center speaker with a new one
Apr 11, 2009 | Audio Players & Recorders
Centre speaker
The controls I would check are speaker set-up and configuration for a multi-channel sound, be sure to enable center channel YES/NO option and trim center channel level output.
Feb 15, 2009 | Kenwood VR-406 Receiver
Yamaha rx 596 problem
ya bad ch unless u know how to work in ther best bet to buy new harmen kardon 7.1 or kenwood 7.1 thx on ebay 250 sound amizing clean warm like tube
Jan 20, 2008 | Audio Players & Recorders
Only sound for cd/dvd
Could be damaged cable between the media centre and bass module (check along cable length for damage, kinks or at DIN plug ends for bent/damaged pins), faulty media centre (unlikely) or fault in the bass module....
Jan 13, 2008 | Bose Lifestyle 48 System
TV to Home theatre
The center speaker shouldn't be on the surround outputs it should be on the Center output. The surround outputs are for the rear speakers.
Sep 09, 2007 | Audio Players & Recorders
Mission 78C Center Speaker Logo
455 people viewed this question
Top Mission Audio Players & Recorders Experts
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
