Using a LCD HDTV with a desktop cmptr ?
Keith, have you ever walked into a fast food restaurant, like McDonald's per se; and said, "Give me a hamburger".
And they did? Just plopped a hamburger on the counter, and there you go?
K.
We have the same problem here. Need the model number of the Nobilis desktop computer.
http://allcomprepair.com/computer_store/computerstore.htm
Post back in a Comment.
Regards,
joecoolvette
http://productreviewratings.com/2011/06/... Easier way to find out. Let's look at what actual hardware is installed in the computer. Suggest use the tiny free CPU-Z from CPUID.com, and GPU-Z. To download CPU-Z; 1) Under the subheading - Download latest release - on the right, click on the purple - 1.62 setup, english. (Has the purple square with the white CPU-Z in it, to the left ) Click on Download now! in the purple rectangle. Give it a couple of seconds; a small window will come up on the right - Opening cpu-z_1.62-setup-en.exe Click on Save File. A small download window will come up on the left. Allow the file to fully download, then DOUBLE-click right on the file name. Click on Run. (Yes it is an Executable file, but No it won't cause any harm. Posting in case you get the Microsoft 'sqawk box' ) Now click on Next, Next, and Finish, at the bottom of the next 3 small windows. After installing close all windows. (Unless, when you have finished installing; it indicates clicking will run it ) Go to the CPU-Z icon on your desktop screen now, and DOUBLE-click on it. CPU-Z automatically opens on the CPU (Processor ) tab. Click on the Graphics tab. What does it state? Also, what does the CPU tab state, as far as Name, Code Name, and Package? This is GPU-Z,http://www.techpowerup.com/gpuz/ Scroll to the bottom of the page, click on the blue - The lastest version is available in the downloads section. Click on the top blue one - TechPowerUp GPU-Z V0.6.6 Go to the right, click on the blue - Download now. (Above - File size: 1.2MB) Pick a server name to download from, click on it. A small window will come up on the right - Opening GPU-Z.0.6.6.exe Click on Save File. Do the same thing you did for CPU-Z, now. Once I have the Graphics information, (And bits of the Processor info), we'll see what the graphics limitations may be.
SOURCE: Dimension 5150 (DIM515MIN) PC Desktop: I want to know what kind of case a dell has. I'm p...
The Dimension 5150 has a BTX case, which is nearly impossible to upgrade. The motherboard is NOT interchangeable (with a few exceptions, but none of which are true upgrades).
If you have a PCI Express slot, you can upgrade the video card but do not get a card that requires an additional power cable directly from the power supply. This is because the stock power supply is very weak and doesn't have outputs for additional cards. If the card requires no additional power, you should be fine.
You can upgrade your processor with the P4 [Prescott] 5xx or 6xx Series Processors with
HT. The 5150 does not support core 2 duo processors. Depending on what you currently have, this may or may not be worthwhile. Also note that higher power processors run at higher temps, which sometimes causes a noticeable increase in fan noise.
The hard drive is easily upgradeable. Just buy any standard sized SATA hard drive. Your computer case supports two drives, so you could keep your current drive and just add a second drive. Remember to buy a SATA cable with the new drive because new drives usually don't come with them.
Overall, if you're looking to get outstanding performance, get a new computer. BTX computers are not gaming computers. You'll end up dumping money into this thing just to get a lousy increase in performance.
SOURCE: reinstalled windows xp pro and
Software & Driver Downloads - Compaq Presario SR1030NX Desktop PC link @ http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=405451#N152
Click on "Drivers - Audio" & download & install "Realtek AC'97 Audio Driver Update" ~size:(10.96M) to your PC.
Hope it helps.
SOURCE: will my video card support connection to my hdtv
It is unlikely to work. VGA is an anlog signal while HDMI is a.digital signal. Hope this helps.
SOURCE: Which cords and/or plugs should I use inorder to connect a projector to a computer
if your desktop doesn't have a standard vga socket then you can get a dvi adapter that fits onto the end of a vga lead. you will still need a seperate cable for audio as a dvi connection only does video.
Nobilis RTS 1208, CA 4/2007 , 916363
