Question about HP PSC 1210 All-In-One InkJet Printer
Printer help How do I connect the printer to my computer?
    President:
  • 2,692 Answers
Epson l100
SETTING UP A SHARED NETWORK PRINTER
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this printer. This means the computer with the printer attached to it MUST be booted up at all times when other computers want to access the printer.
You need to install the printer driver on the computer and configure it as a Shared printer.
The other computers on the network need to add this printer to their computer.
Follow these steps to set-up a shared network printer -
1. Connect the printer to the computer and install the printer driver.
2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click
Share this printer, and then if you wish you could change the Share name, then click OK
3. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
Follow these steps to configure the computers on your network :-
1. Open Printers and Faxes - click Add a printer - Next - select a network printer, or a printer attached
to another computer - Next.
2. Select Browser for a printer - Next
3. Click on and expand the Microsoft Windows Network down to the computer with the printer - Next
4. Select Yes for - Use this printer as the default printer - Next - Finish
5. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
May 07, 2013 | Computers & Internet
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
Printer Problems
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 15, 2012 | Lexmark X5650 AllInOne InkJet Printer
Adding my printer back on my computer without the disk
  4. Reboot computer.
Jan 04, 2012 | Lexmark Z600 InkJet Printer
No connection There is no computer connection.
Hello !
Give this a try;
Go to Printers and Faxes and delete your printer icon.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. If it does not, move the USB cable to another port on your computer. It's also possible that your USB cable is faulty - replace the cable.
Install the printer driver.
Hope that helps.
Oct 15, 2009 | HP Office Equipment & Supplies
I have a samsung scx4300 connected as a network printer. It will print from the computer it is directly connected to but not from the network. Can anyone help
Click start, click control panel, click printer and fax, right click the printer icon click printer sharing and follow the computer instruction till it finish. Go to the other PC click start, control panel, printer and fax click add printer, and follow the computer instruction except for the computer will as to locate printer click the network printer and the printer will appear click the printer this will add to the PC. now you can print to that PC. Hope this will help you.
HH
Aug 12, 2009 | Samsung SCX-4300 Monochrome Laser...
Cannot connect printer to computer
First of all you must connect the cable that came with the printer to the computer and power on the printer by plugging the power chord then you need the printer driver software which you can download it from the internet from the website www.driverpool.com by specifying your printer model no later you have to install the printer on your computer
May 28, 2009 | Epson Stylus Photo R320 InkJet Printer
Switching from copy to print from computer
If you look carefully at the printer you'll note that there is no button for "Print" and the reason for this is that all the other functions are for using the printer as if it wasn't connected, nor needed a computer.
All your printing functions that DO use a computer require you to interact with the printer via the computer.
In short, to use the printer from the computer you'll need to make sure you've installed the correct drivers (see your installation CD or the Canon website) and then plug the printer in using a USB cable connection to your computer. If the computer recognises the printer you'll then be able to print.
In a nutshell if your printer is connected and drivers installed properly it doesn't matter what your printer has selected on the printers own control panel, you just print :)
Hope that helps.
Feb 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Need help connection my printer
Install the software if you didnt already for the printer.. Does the computer reconize the printer? Does the printer throw any codes? Has it ever worked?
Mar 15, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
19 people viewed this question
Ben Johnson
