Question about Nikon N55 35mm SLR Camera
N55 took the last picture the film rewound and then we went to put in the new film and it wont advance. changed out the batteries thinking that was it and still nothing. Now what?
    Genius:
  • 2,985 Answers
Go digital- Seriously Take batteries out and clean the contacts in the base of the chamber with the eraser on the end of a pencil and clean the cover contacts remove the cassette and reload Then try- but if it is automatic and has died then a repair option may not be possible because of lack of parts unless there are secondhand ones to be had and the cost could be big bucks
Posted on Jun 13, 2007
Film does not advance in my n55
is the film far enough to the right so it engages the sprockets ?
Sep 14, 2012 | Nikon N55 35mm SLR Camera
My nikon n55 is flashing err after installing new film
It could be that your camera doesn't know it's rewound the film already. With the camera turned on, push and hold BOTH manual rewind buttons simultaneously - one near the release button ( +/- ) and the other toward the front of the camera at the lens release button. Try the release button again.
Jan 03, 2009 | Nikon N55 35mm Film Camera
Camera froze up Type Canon Sure Shot ZOOM-S
Sounds like the film either didn't advance thru the camera or its been rewound.
Here's a copy of the user manual:
http://www.cameramanuals.org/canon_pdf/canon_sureshot_prima_105_zoom-1.pdf
Dec 25, 2008 | Canon Sure Shot 105 Zoom S 35mm Point and...
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Flashing Err and E/Error Problem
You might want to check the position of the aperture ring on the lens. If it is not set at the highest number, ( IE smallest aperture, f22,f32 ), then the camera will display that error message
Dec 17, 2007 | Nikon N55 35mm SLR Camera
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
F--
Unlike other cameras that start at frame #1 after loading and count up as the film is used, the N55 advance the film to the last frame during the loading process. When loading is complete, the frame counter stops at the number of available frames on the roll (usually 24 or 36) and counts down as photos are taken. I know it sounds backwards but it actually makes a lot of sense to engineer it this way. After the last photo is taken (displays 1 on the counter), the camera automatically winds the end of the film into the cassette and the counter shows a blinking E. I am assuming that that is what is being displayed and not a blinking F. it it is an F, perhaps there is a problem with the LCD display? If so, it probably isn't worth having it repaired.
Jun 26, 2007 | Nikon N55 35mm Film Camera
Nikon N55 35mm SLR Camera Logo
69 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
