Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Minolta biz hub 250 ...problem error code c3451
Check fuser thermistate plus thermistor ...good
what is the reset on this model? is it power off / hold down utility, power up / troble reset / restart
  • 4,041 Answers
Hi there.
Please try .
Try this.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
    New Friend:
Hi is little dificult.At right of the machine near to usb port is a little cover push it and pull it down you can see the firmware port and near is a little buton.Turn on the machin when the code is appear push the buton.Machine will restart and will be appear the little cross,push the number 3 a little window will be appear down on the screen push 8 times 0 and push the "end"on the screen will be appear a new window tuch trooble reset and the machine will restart.you can work now.
Posted on May 09, 2013
  • Celeste8199 Sep 23, 2013
    This really Works!! Thank you for saving me$$$ with tech support.
  • jhonny
    jhonny Oct 22, 2013
    gracias por su ayuda si funciono
Malfunction c3451 detected for bizhub 250 konica minolta
Try this It could do the trick for you.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
Jul 23, 2014 | Office Equipment & Supplies
What is C6030 on Kyocera Km-C2520
6030 Broken fuser thermistor M wire
*35/37 and 45/47 ppm printers (EUR/
USA model) only
Input from fuser thermistor M is less than
1 (A/D value) for more than 3 s.
Poor contact in the
fuser thermistor M
connector terminals.
Reinsert the connector (See page P.1-5-19).
Broken fuser
thermistor M wire./from the manual try replacing thermistors then reset the code or just replace fuser then reset the code
from the manual sadjnbdsvknsdlkvnsdv
Apr 12, 2014 | Kyocera FS-2000D Laser Printer
Error c3451
Fuser not getting warm enough, first check if there is paper wrapped around the upper fuser roller, if so remove it and reboot the machine.
If this is not your problem then your thermistor inside the fuser unit needs to be replaced
Oct 15, 2013 | Minolta bizhub 200 All-In-One Printer
I get a code c3451
C 3451 and C 3452 Fusing warm up malfuntion.Verify the fuser unit and clean the thermistors and the thermofuses and try reset the error code.For reset press following keys:
Utility - Meter count - Details - Stop - 0- Stop - 0 - 1
introduction 0-0-0-0-0-0-0-0 press enter and select the trouble reset(counter windows).
Feb 14, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
How much is a fuser unit for a bizhub 250? I got a c3451 error.
around 250-280 $ (include shipping) but you may need a technician to clear counters, reset error code, and install and test the new fuser. If you want to do it by yourself, may be time consuming.....
Feb 22, 2011 | Konica Minolta bizhub C250 All-In-One...
Bizhub 250 All-In-One Laser Printer: Error code C3451 wont reset using Utility key at s...
• The Fusing Roller Thermistor does not detect
the required temperature within 30 sec. after a
warmup cycle has begun; therefore, the copier
does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
May 16, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Error c3451
this is a fuser temperature too low error code could be the thermistor or heat lamp is not comming on to reset the error code turn the main switch off the main switch is located on the left side opf the machine towards the rear and while holding the utility/counter button down turn the switch on hold the utility /counter button down until trouble reset appears on the touchscreen then release theutility button and touch the trouble reset button then turn the main switch back off and wait at least 10 seconds then turn it back on if the error code comes back have the fuser unit replaced
Nov 09, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Sep 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Error c3451
First ignore the revious solution, it is not even close. The error code c3451 refers to a copier warm up error, the machine had not reached the correct temp within a specific time. I bet it happened when you first swiched on one morning. Easy to reset and fault usually goes away.
hope this helps
Jan 09, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
7,618 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
