Question about New World G90m Gas Double Oven
Grill fan sounds like an old morris minor
We have an NEWWORLD G 90m from 2005. The grill fan makes funny noises, its very slow, sounds like an old tape recorder and the sound is also irregular. what can we do about it?
  • 334 Answers
Replace the fan motor.
Apparently it is going bad.
You should be able to find a replacement for less than 60 bucks at your local appliance parts warehouse.
You may try cleaning it if it is coated with stickiness or grease.
But chances are, if its already slowing down and making noise, its beyond saving.
Posted on Jan 14, 2009
My new world double oven fan makes a loud noise and now the large oven does not heat up
Newworld model 444447289 made a loud bang and doesn't come on. The top oven oven is ok. What could the problem be
Oct 11, 2013 | Ovens
Hi, I have a Zanussi ZBF
Your fan is catching the element which has distorted with heat
Oct 04, 2017 | Zanussi Ovens
When i switch grill on fan makes a loud noise
Sounds like a worn bearing oe bearings, or possibly a loose fan blade, ypu wiil have to check the fan to see which it is.
Dec 14, 2010 | Ovens
My oven fan is making noise what should i do?
check to see why it is making noise. look at the fan while it is spinning DO NOT INSERT YOUR HANDS and see if you can see what the fan is hitting and why it would be hitting whatever it is hitting could be the shaft onthe motor is maybe bent or a blade is bent on the fan blade itself or maybe something fell into the fan and that might be makin the noise hope this helps
Jul 17, 2010 | Ovens
Newworld dfeo 90 main fan oven not heating - fan works! - which part most likely faulty
If it is an electrically heated fan oven, then I would suspect the oven element has failed, this is at the rear of the oven compartment behind a removeable cover.
If it is heated by gas, then I do not have an answer for you,as I have no knowledge of gas ovens.
Hope this helps.
Jan 30, 2010 | Stoves Ovens
Noise
It will be the external cooling fan that is causing the noise.
Probably worn beaqring or broken fan blade.
Normally, the only solution is to replace the fan motor.
It is located at the top of the oven, usually at the rear, but not in every case.
Please rate my solution.
Thankyou.
Jan 23, 2010 | Zanussi Ovens
Some panel in my Neff electric oven is making a loud vibration noise on fan mode. The vibration noise stops if the top part of the front surround (with door open) is pushed in. There is no vibration on...
Update: after using the oven with the grill instead of the fan, the problem sorted itself. With the heating and cooling, obviously some panel had not settled correctly and was causing the vibration. It hasn't happened again so far.
May 19, 2009 | Neff Ovens
Whirlpool oven
There is a fan in the oven, it is behind a panel at the rear.It will be a loose fan or worn bearings, or fan catching grill
Nov 09, 2008 | Whirlpool RBS275PD Electric Single Oven
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
New World G90m Gas Double Oven Logo
273 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
