Question about Microsoft Office Professional 2007 Full Version for PC
How can i connect jdbc odbc to do my program
That means the way to create connections in the administrative tolls services
    Genius:
  • 1,605 Answers
Create a System DSN in Windows XP loadTOCNode(2, 'summary');
  1. Click Start, point to Control Panel, double-click Administrative Tools, and then double-click Data Sources(ODBC).
  2. Click the System DSN tab, and then click Add.
  3. Click the database driver that corresponds with the database type to which you are connecting, and then click Finish.
  4. Type the data source name. Make sure that you choose a name that you can remember. You will need to use this name later.
  5. Click Select.
  6. Click the correct database, and then click OK.
  7. Click OK, and then click OK.
Posted on Jan 14, 2009
I have to make minor project on java and i know core java and jdbc odbc connectivity will u please help me
It would probably be wise to post this on a Java forum (like this one, this one, or this one), as they will be able to help you better.
Alternatively, try Stack Overflow.
Feb 19, 2010 | Microsoft Windows XP Professional
How to insert datepicker value in access with use of C#
1.U have to create one acess database .
2 create connection to database using odbc or oledb connection.
3.Write one insert query.
4 execute that query.
5.close the connection
Nov 16, 2009 | Microsoft Visual Basic .NET Standard 2003...
I am trying to connect to a SQL Server 2005 DB from Visual Studio
You must create an ODBC connection to your SQL database in the Windows Control Panel. Than you can call your ODBC connection via Visual Studio 2005. You can also create a DSN in Visual Studio 2005 and reference in that way. You will not be able to connect to an MDF but instead you have to connect to the SQL Server Service. Of course the username you use to connect must have access that will be created on the SQL server.
Apr 13, 2009 | Microsoft SQL Server 2005 Standard Edition
How can i connect the data base during my project
That seems fine.
I cant assume your level of confidence in programming, however, following are some simple steps you can follow to achieve (for complex implementations, much more time and details will be needed, i can help u with them as well)
1. Create a database in Access ( i assume u r using Access 2003)
2. Create a System DSN (if aren't clear, how to create then goto administrative tools under control panel and you'll find Data Sources (ODBC), here u need to create System level DSN for Access driver (may be Jet 4.0+)
3. In java, you need to import java core libraries for sql (javax.sql package specially)
4. you are almost done, just google for database code in java, simple code will be around 5-10 lines (just for your reference, search with these keywords, ClassName(""), jdbc:odbc:YourDSN)
5. Open a connection using Connection object
6. Fetch the records (select query) using Recordset object
7. You're done.
thanks
Kuldeep
Mar 13, 2009 | HP Computers & Internet
How to make a connection with sybase using jtds driver
hi,
the first thing you need is the correct JDBC driver, that must be included with your database.
Then you need to create a connection using the driver.
This link could help.
http://www.redmountainsw.com/wordpress/archives/jdbc-connection-urls
regards
Mar 13, 2009 | Sybase SQL Anywhere Studio for Workgroups...
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
What is use of Jdbc or odbc driver?
Go through these links to get an overview of JDBC and ODBC:
http://en.wikipedia.org/wiki/Java_Database_Connectivity
http://en.wikipedia.org/wiki/Open_Database_Connectivity
Jan 17, 2009 | Computers & Internet
How to configure odbc for multiple user in windows 2003 server
You can also try adding the datasource as a System DSN instead of a User DSN. Of course, all users on a given system will then have access.
Apr 03, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Office Professional 2007 Full Version for PC Logo
85 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
