Question about Hoover HDC7FM Dryer
Intermittantly not operating
We have a hdc7fm and when you press the ON/OFF button the dryer turns and heats up but stops immeadiatly when you release the ON/Off button. This does not happen all the time and it does not matter what the positon the timer is set to. I have replaced the timer as this had a seperate fault but the problem was there before I replaced the timer.
  • 3 Answers
If its gas check the flame out switch
if its electric u may have a bad on/off switch
Posted on Jan 14, 2009
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
If i press the power button the dryer goes on but once i stop pushing the button it stops. I tried to keep the button pushed but the dryer doesnt heat up inside.
what kind of dryer is it and send the model number,if it's a whirlpool/ kenmore and it has even heat you have a bad even heat board...copy and paste and read this,it should help you out...............http://fixitnow.com/wp/2003/12/20/mailbag-dryer-stops-when-the-start-button-is-released/
Apr 25, 2011 | Dryers
Hoover Dryer has stopped completely, no prior motor noise/smell
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 27, 2010 | Hoover HDC7FM Dryer
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Dryer heats randomly..Igniter is working.
Generally operation when cold that worsens with use indicates a component that is failing when hot. Start at the burner with the coils and work your way back to relays on the control. Sounds a lot like a bad coil on the burner. I have seen these do 2 complete loads then fail. Setting over night and cooling off will work again the same way. Intermittent conditions are a real challenge sometimes.
Eric
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
Dryer works fine but does not heat up
Hi, looks like there's 1 of 2 faults. Either the stats or the heating element. They are located at the back of the TD, covered bi a screwed panel. If you have a multimeter, turn it to buzz and check the connections. If the meter buzzes it's ok, if the meter doesn't buzz it's dead and needs replacing.
Cheers
Feb 19, 2009 | Hoover HDC7FM Dryer
Hoover HDC7FM Dryer Logo
124 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
