Question about KitchenAid KERC506HBS Electric Kitchen Range
Oven not heating KitchenAid KERC506HWH3
The oven does not heat. Everything on the range works including the display. When you turn on the oven you can hear clicking noises but it will not activate the heating elements. I tried all the combinations of convection, bake, preheat and broil. Is this a problem with the oven sensor or the control panel? How do I tell? How do I test the sensor to see if it is working?
  • 1 more comment
  • Lucky Billings
    Lucky Billings Aug 01, 2007
    As it turns out the range is made in Canada. That model has a fuse built into a wire leading to the control panel. It can blow and cause this problem. I replaced the wire with the American version which does not have said fuse in it and it works. The solution came from the local repairman not me and he said that it was not likely I would have found it. This is only a problem with the Canadian version.
  • steve4reno Mar 09, 2008
    I have the same problem, Which Wire has the fuse?
    My problem is the same, I will replace the fuse to protect the oven from another electrical surge we had duringa storm.
    I just need to know where it is located, which line, If I can find it I can find a replacement.
    Is it a LIKE A THERMAL LINK OR JUST A REGULAR INLINE FUSE
  • 183 Answers
If this cooker is fitted with a clock check that it is not set to delay start mode(auto) if it is reset clock and this will resolve problem
Posted on Jul 28, 2007
Feature not available
I had the same problem with a new kitchenaid range which they have agreed to replace after 1 month. Oven shut off a couple times while baking and feature not available displayed when trying to turn on oven again. I tried starting clean cycle and waiting a couple minutes for element to heat then cancelled clean cycle. Oven worked fine after this but this shouldnt be a solution, obviously something not wired right.
Dec 09, 2013 | KitchenAid KIRS608BSS Induction Electric...
This is probably the thermal shuttoff fuse. Usualy mounted in the back of the oven. Aftermarket fuses are resetable but the OEM ones that come with the ovens usualy are not, so when they go out they stay out. This shuttoff only effects the power to the element so the rest of the oven appears to work.
The oven has to come out and remove the rear covers, behind the covers you will see 2 wires that go to a small 1/2 in dia "plug" that mounts directly to the surface with 2 screws.
Remove the connections and put a meter across the cuttout. it should read very close to zero ohms, if not its blown.
Apr 23, 2009 | Frigidaire FEB27T5D Electric Double Oven
Kitchenaid KDRP463LSS - No electricity to oven
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
partimage.aspx?imgid=z3bqljffahrfnza4nzu3os9mufcvc290b2hwdhjhcc8%3d
The oven TOD
partimage.aspx?imgid=z3bqljffahrfmja4mdazoc9mufcvc290b2hwdhjhcc8%3d
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Dec 22, 2008 | KitchenAid KDRP463LSS Dual Fuel (Electric...
Built-in ovens have a thermal fuse mounted in the back of the oven preventing the bake and broil from operating. In some cases this fuse will open after a self clean operation. In some models, the cooling fan turns off too soon, causing an overtemperature condition that may also cause the fuse to open. You will have to remove the oven and take off the back panel to gain access to this device.
May 25, 2008 | Frigidaire PLEB30T8A Electric Double Oven
Electric Oven not getting hot enough
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
Feb 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
It could be the sensor. Remove the sensor and check for 1 to 1.1K ohms. at room temp. If that's not the problem it may be the oven solenoid on the burner. You can also have a problem with the door lock making when it shouldn't check that also.
Dec 21, 2007 | Kitchen Ranges
Need to check and see if you are getting 220 volts to the element or if the element is showing resistance with an ohm meter. Any resistance means it is ok. If you are not getting voltage to the elements and resistance is ok then the control board is bad. Note: Always check outlet for proper voltage first! Never know when a breaker has gone bad. Should have 220 volts from line 1 to line 2 and 110 volts from line 1 or line 2 to ground.
Nov 16, 2007 | Kitchen Ranges
KitchenAid KERC506HBS Electric Kitchen Range Logo
593 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
