Question about ASUS Eee 4G Notebook
No educational progams on pc
Bough pc with windows xp on. no educational program and web cam dont work.
  • 4 more comments
  • rosa584 Jan 15, 2009
    NO MATH, LEARN, GAMES PROGRAM AS INDICATED IN BOOK AND BOX. NO DICS IN SIDE OF BOX TO LOAD IT
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    If it didn't come with any programs, then you must go out and purchase them and then install them.
  • BillW50 May 11, 2010
    Did you toggle the webcam on in the BIOS Setup?
  • DEKR
    DEKR May 11, 2010
    what programs did they say it came with
    your cam
    I would unplug and uninstall restart put cam cd back in follow instructions it should tell you when it's okay to plug cam in usually requiring restart
  • DEKR
    DEKR May 11, 2010
    How was the webcam installed and did it come with a cd
  • Dan rogers
    Dan rogers May 11, 2010
    what do you mean by educational program?
  • 3 Answers
POST
Posted on Jan 29, 2009
  • 114 Answers
I have both Linux and Windows XP versions of the EeePCs. And the Linux version comes with some educational software. While the Windows XP version does not.
The vast majority of no webcam is because it is toggled off in the BIOS.
Enabling the EeePC Camera through the BIOS
Go into the BIOS Setup (press F2 when the screen lites up).
Right arrow key to Advanced
Down Arrow key to Onboard Devices Configuration
Enter
Arrow key down to Onboard Camera
Enter
Arrow key to Enable
Enter key
F10
Enter
Hopefully that takes care of it. :)
Web cam does not work after a company put windows xp on when it came with windows vista the web cam program is Quick Play
Hello visit your pc`s homepage, to download the webcam driver.
The quick play software should also be available there.
ALL drivers are lost when a new install is made, and the vista driver does not work with windows xp.
Good luck
Jan 10, 2013 | Computers & Internet
My program "Redshift 3' will
try to uninstall and reinstall the program then run it using the administrator mode.
Jul 11, 2011 | Vivendi RedShift 3 (02200) for PC
How do you turn on web cam
Normally, PC webcams are run by a program. Some of those programs include YouCam, YawCam etc. Check your start bar if you can see any of the progams.
A clue to help is this; most webcam programs have the word CAM attached, so in your search bar on your start menu, type the word CAM, and see what it brings up.
The webcam program usually has an 'eye - like' icon.
When you have located it, launch it, and your webcam would be turned on.
If typing 'cam' on the search bar on the start menu does not bring forth results, then, your Cam program is one of those that dont have the word 'cam' attacheed.
You would have to search your program list manually, and look out for any program with an 'eye-like' icon.
Hope that was helpful to you?
Regards.
May 26, 2011 | Compaq Computers & Internet
My web cam dont work ,its works on wind xp but when i instal wind vista so web cam dont work
It may not be compatible with windows Vista. You may have to Google the manufacturer of the webcam and look for information to see if it is indeed compatible. If it IS compatible then you may have to find the vista drivers for it.
Oct 29, 2010 | Computers & Internet
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Software runs until I power down at next power up software dies.
I would suggest purchasing the version of the Mavis Beacon Teaches Typing v 1.5. It's compatible with Windows XP. I've also looked at the software description and you are able to select the age group of the typing test.
However, if some reason you have to continue with the same version. What error message do you recieve?
Thank You, Raphael
Jan 21, 2009 | Mindscape Mavis Beacon Typing for Kids...
DRIVER
plz downlaod the driver
Jan 02, 2009 | Creative Labs PD1001 Webcam
How can i download a4tech webcam coz i dont have installer?
I HAVE A PROBLEM WITH MY WEB CAM I LOST MY CD N NOW I CANT INSTALL MY WEB CAM HOW CAN I DO IT
MY WEB CAM MODEL ITS PK-635
Jul 12, 2008 | A4tech G-Cube Cosmo-tini notebook webcam
Web cam drivers for model CS330
i want to download drivers for usb web cam oprating system is xp
May 15, 2008 | Intel Deluxe PC Camera CS330 Webcam
ASUS Eee 4G Notebook Logo
198 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
