Question about HP Compaq dx2300 Microtower - RT950UTABA PC Desktop
Pci error when the comp boot it detects a new pci device,when i try installing the device using windows installer i does not install.then the computer hangs.please help
  • 1 more comment
  • stevekibe Feb 05, 2009
    i formatted my compueter and now it cant play any sound though the speakers are working, besiodes it detects a new PCI device in the Device Manager panel but when i try installingn it does not pick. any solution please? Kibe from Kenya
  • kabmfy May 08, 2009
    my pc does not make a sound hp Compaq dx2300 microtower what should I do?
  • rebelyes1 May 11, 2010
    what device does it want you to install?
  • 47 Answers
I would suggest that you cancel the device installation, download the drivers for various components (Sound, Chipset, Network etc.) from the HP website. Install those drivers and restart. Check if that new device found message comes again and let me know.
Hope it helps.
Love.
Posted on Feb 09, 2009
No sound
Hello
Make sure the audio jumpers on the motherboard is in the correct position.If possible,refer to the manual of the motherboard to verify the settings
)Are the speakers you using is working and powered on.Check out in another computer,if possible
Try to remove all expansion cards example modem,DVB-cards etc.Just install the video card thats all and then check the sytem.
Have you connected to the right ports of the computer.
Is the audio device built-in on the motherboard or is it a PCI card?
Try to remove all drivers from the device manager and extra software you might have installed and reboot.See if windows detects it or not.
Motherboard could be faulty or the PCI card whichever you have
If it is a PCI card,remove and reinstall.If possible try using different set of speakers
Remove the PCI card,if it is one,Try to reinstall windows,if possible and don't try installing the drivers at the start of the computer.Soon after windows finish installing,Shutdown the PC,insert the card and then boot system.See if windows recongnizes it or not.
Jan 22, 2011 | Intel D845GVSR Motherboard
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
I have installed a P5KPL-AM IN/GB Motherboard from which it will not install Windows XP from CD. It Boots up normally then stops with a message "A problem has been detected and Windows has been shut down...
this could be a wealth of issues. check to see if all the hardware is compatible with the new mobo. if you're not sure try disconnecting different bits of hardware to see if you can get past the system error.
go into the bios and make sure the cd drive is listed as the first device in boot priority
Feb 25, 2010 | Computers & Internet
"no audio device installed"
First check the device manager from the control panel. Check and see if there is a audio device detected and if it is a problem device.If the device has a problem try removing the audio software and then remove the audio device.then re-boot the computer and windows should detect the hardware and begin installing drivers. Make sure you have the updated drivers from Dell downloaded and the updated software. If it does not detect the hardware after re-boot you can try adding hardware manually in the control panel and have it auto detect any new hardware. If these thins do not work the audio card or built in audio may have stopped working. You can buy a basic PCI audio car for fairly cheap to install on your computer if you cannot get the audio to work.
Sep 05, 2009 | Dell Computers & Internet
Error: PCI on motherboard and strange wireless/driver issues.
just remove the CMOS battery and restart the pc
worked for me.
Aug 27, 2009 | Gateway M460 Notebook
Audio is not working for P5SD2-VM motherboard...
You probably need Microsoft UAA drivers first
1) Remove any installed audio drivers through device manager
2) Download Microsoft UAA drivers for your O/S
3) Install them and reboot
4) go to device manager right click sound and update driver
It will go on the net and in most cases find and install them
Nov 28, 2008 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Tyan S3992 MOBO with scsi drives and tape drive
Only if your BIOS supports booting off the particular device. You could also try to swtich the two PCI slots. Put the tape drive controller in the 1st slot,and the SCSI controller in the 2nd slot.
Which tape drive is it? Is there a firmware update for the BIOS for that PCI controller? I would perhaps contact the vendor of the tape drive/controller
Feb 23, 2008 | Computers & Internet
Trying to boot from a hd from my old comp
MS Windows XP when installed to an HD will "marry" itself to the hardware of the original computer specifically the motherboard. Transplanting the HD to another PC with a different motherboard will result in a cycling blue screen of death or protective message requiring that you reboot. Running in Safe Mode will not also be allowed.
You need to re-install your OS (boot from CD) but choose the 2nd repair option rather than a new/clean install or the first repair option if you want to preserve your other applications as well as your settings/configuration. Doing this will allow the OS to install the new device drivers and delete the old ones.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
God luck and kind regards.
Jan 13, 2008 | Computers & Internet
PCI adapter did not install
I don't know how you could have installed the drivers BEFORE you installed the hardware... Shut down and UNPLUG the system; REMOVE the new PCI card, then hook up the power and boot the system back to the Desktop. Check the Device Manager to be sure you're not showing any problems; if everything seems back to normal, shut down and unplug the system a second time, then install the PCI card again, restore power, and prepare to reboot the system. Be SURE that ALL of the PCI cards are fully seated in the slots, and that the main power cable (from the PSU) is fully seated in the connector; IOW, check the system just to be sure that nothing has come loose while you've been working inside the case. Next, boot the system again; Windows SHOULD detect the new PCI card during bootup, though it might NOT request drivers, if they are already embedded within XP itself... Once you get back to the Desktop, open the Device Manager and check to be sure that the new card has been detected and properly installed. If you see any question marks, error messages, or exclamation marks, take detailed notes, and post that information here, so we can help you troubleshoot the problem... Good luck; I can only give you general advice about this, because you didn't provide any specific details about your new hardware, but with a little luck, you'll get everything working without any more heartburn...
Mar 31, 2007 | D-Link DU-520 - 5-Port USB 2.0 PCI Adapter...
Error code 10 Device cannot restart
Generally a code 10 refers to a dead component unfortunately.Although the card will be recognised.
Aug 29, 2006 | U.S. Robotics MAXg USR5417 802.11g/b...
HP Compaq dx2300 Microtower - RT950UTABA PC Desktop Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
