Question about Epson Stylus Photo R200 InkJet Printer
Epson Photo R200 unrecognised cartridge message
I have an Epson Photo R200 and I use compatible ink cartridges, Worked fine when I was running Vista but I changed the operating system to XP a couple of days ago and now I get an unrecognised cartridge message and the printer is inoperable.I reinstalled the drivers as before and the same cartridges are in the printer. Any ideas?
Problem solved! I moved each cartridge up slightly to break contact and then snapped them back into place. Loaded a job up, pressed print and it started with no problem.
Posted on Jan 15, 2009
Epson rx595, installed compatible ink cartridges some time ago and it worked fine, now the yellow and the light magenta given error (cannot recognise ink cartridges,) put original epson that are empty back...
Swith machine off
clean pins in cartridge holder with (lightly) damped lint free cloth
Now try with compatibles
By the way, never mix originals with compatibles.
Good luck and don't forget to vote for more sharing.. thank you
Nov 22, 2010 | Epson RX595 Photo All-In-One Printer
Photo R200 won't print
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 04, 2010 | Epson Stylus Photo R200 InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Ink Cartridges
There is a patch for Vista users. Try to install it, it should solve the problem
Nov 04, 2008 | Epson StylusRIP Professional (C12C842862)...
Epson photo r200
Sadly, if only one cartridge is empty, an Epson printer won't print. But, you can bypass that by using a chip re-setter. They have them in refill stores. By using a chip re-setter, you assign a new serial number to your cartridge, thus "fooling" the printer you have put a new cartridge in. Then, you don't need to refill all the cartridges.
Sep 09, 2008 | Epson Stylus Photo R200 InkJet Printer
How to refill Epson Stylus Photo R200 cartridges
The continuous ink kit is on sale in Canada at "The Source" (former Radio Shack stores, now owned by Circuit City --- www dot thesourcecc dot com ). Search for R200. Also the photo Cyan and Magenta original epson cartridges are under $3 and the others under 10.
Jul 28, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
For the Epson R200 here's how I got it to work with Vista Business 32bit ...
#1 Disable AV software
#2 Open the CD for the printer software
#3 Find the launcher, right-click it and select Properties, then select the Compatibility tab
#4 Choose XP SP2 compatibility mode and Run As Administrator, then click OK.
#5 Double-click the launcher to start the program, select Custom then then choose only the Driver and Status Monitor applications.
Worked for me, hopefully will do too for you. :o)
Jul 05, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Problem
i have a R220 it says it needs a service can you help
Feb 19, 2008 | Epson Stylus Photo R220 InkJet Printer
Epsom R200 COPY INK DOESNT WORK
There is no solution, I have tried this myself, there are compatible inks for this product, you just got the wrong ones, However it may only be down to one of the inks, check the ink levels before removing, if all empty, then they are not compatible.
swampduck
Jan 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson photo r200 will not print
so after reseating all the cartridges and doing head cleaning from the computer / driver and still not getting any output on the paper :
if it´s not the printer - hopefully it´s the ink
have them replaced, contact the manufacturer
Dec 23, 2007 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
142 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
