Question about Dell Inspiron 1525 Laptop Jet Black
Screen not working
Laptop seems to be booting up and back light is working. I think the cable has come loose connecting the base to the screen. How do you get it apart to re-attach?
  • Dell Master
  • 998 Answers
Here's a link to the Inspiron 1525 service manual: http://support.dell.com/support/edocs/systems/ins1525/en/SM/display.htm#wp1179838
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Jan 14, 2009
Laptop goes
You must, when using an external monitor, either press the relative 'F' key to switch the external signal on or boot with the external monitor plugged in to get it to work.
Mar 24, 2014 | MSI A6200-059US Laptop
Now my screen says gateway very dim and goes black
The screen on your laptop computer is the primary graphical interface that allows you to interact with your Gateway laptop computer. The screen is connected to your computer through video cables located within the base of the laptop. If your laptop will boot up but the screen remains black, it is likely the video or power cable on your Gateway laptop has somehow become disconnected. Reconnecting laptop hardware is a very difficult operation and is not recommended for anyone that is not familiar with computer hardware.
Remove the faceplate of your old laptop by removing the plastic hinges located on the sides of the base. The hinges can usually be removed with your fingers. Open the latches that secure the keyboard to your laptop. Some laptops use screws to secure the keyboard; remove these if necessary and unplug the connector. If you are having trouble finding the screws on your laptop, they are normally located near the corners. Unscrew the screws that connect your laptop screen to its base. The screws will be located near the bottom of the screen's base. Reconnect the video cable and power cord that connect your screen to your laptop and make sure they are firmly connected. Reassemble your laptop to complete the operation.
Feb 26, 2013 | Computers & Internet
Back light sometimes works
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 10, 2012 | Acer Aspire As5250-0327 320gb - Perfect...
M4400 screen install
You will have to remove the plastic strip that is around the lcd screen. Normally there are little bumpers on the plastic strip that you have to remove because they hide screws under them. Remove the bumpers, remove the screws, they gently pry the plastic strip off.
The screen itself is secured on brackets by screws, so just remove the screws from the sides of the lcd screen that secures it to the bracket. Afterwards you can bring the lcd forward as if you are closing it and the screen will fall into your hand. You don't want the screen to fall all the way out too far because there is a cable in the back of it that you will have to remove. On some models you might have to remove the screws from the brackets at the four corners to get the screen out.
Replace with lcd screen with one that is designed for your laptop, otherwise you'll be sorry.
May 06, 2012 | Dell Computers & Internet
There is a white screen when i turn my macbook on but nothng more
Since so many different brands and models of laptops exist, specific causes of a white screen vary from laptop to laptop. The likely cause in most cases of a white screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard. The issue can also reside strictly with the motherboard or the screen might contain a defect.
You can diagnose a white screen problem by opening up the laptop display case to determine whether a loose video connection on the back of the LCD screen exists. Reconnecting the video cable should resolve the white screen; a video cable reconnection that does not fix the white screen narrows the root cause to a problem with the motherboard or the screen.
"Motherboard Problems"
The only way to determine if the laptop screen turns white due to a motherboard problem is to test out a different, working LCD screen with the laptop. This requires the user connect the inverter board--the power supply for the LCD back light--and the video cable to the test LCD. If the test LCD works with the motherboard, then the laptop's screen needs replacing; otherwise, a new motherboard is needed because there is no way to replace an integrated graphics card on a laptop motherboard.
Thanks.
Nov 02, 2010 | Apple MacBook Mac Notebook
My compaq presarero laptop boots up but screen will not come on
This is a problem I've seem before. The connection is probably loose to the screen, or it's faulty. There may be other problems.
Aug 28, 2009 | Compaq Presario Notebook
Samsung v20 display keeps going i have changed the screen cable
sounds like your new screen cable is either loose or faulty.i had same problem and was only after i had removed keyboard and ensured cable was tightly connected did i solve the problem.it seems to be a design fault in the samsung v20
Jan 24, 2009 | Samsung V20 XVC 2400 Notebook
IBM T40 Laptop screen goes black, will not come back
First of all, you have to check whether you can see video signal with surrounding light tilting the screen.
If you can see dim image, all you have to do is replace back-light inverter or fix it. Usually, the fuse is open and you can connect it by simple soldering.
If you can't see dim image, it is another problems.
Give it a try.
Dec 09, 2008 | IBM ThinkPad T40 2373 Notebook
Compaq presario 1700 LCD issues
i have the exact same problem. try connecting the laptop to an external VGA screen. if it works, then the problem is most likely a loose cable (connector). It turns out that the connector (which connects the motherboard or gfx card to the LCD screen) on my laptop is torn and cut. see if u have the same problem. this link might help u check out ur problem:
http://www.laptopparts101.com/lcd-screen-video-cable/
Nov 21, 2008 | Compaq Presario 1700 Notebook
Dell Inspiron 1525 Laptop Jet Black  Logo
129 people viewed this question
Alun Cox
