Question about Lexmark E250dn Laser Printer
Bulb sign light is flashing. Hence printer doesn't print
Bulb light on the front panel is constantly flashing and the doen't print.
Off course there is problem but what's casusing this.What are the corrective measures for it Lexmark E250d.
Well I kept trying to find out the solution as I don't have any user's guide with me and finally I got a hint. I just reinstalled drivers & related software which solved the problem. Printer is new
there cann't be any other type of problem like toner or developer etc. So this is a very positive approach to reinstall the software.
Posted on Jan 15, 2009
The TV is off, but the red light on the front is flashing. What does this mean and how do I reset this???
It is normal for it to flash for about 10 minutes after turning it off, while it cools down the bulb. You're not supposed to try turning it on during this time. If it is flashing constantly, it is telling you the bulb needs replacing.
Apr 06, 2016 | Sony KP-57HW40 57" Rear Projection...
Frigidaire Model NMER336FS0 How do I change the interior light bulb in the drum?
Unplug the dryer first, of course. With a putty knife, locate the clips under the front of the main top to release the spring clips. Lift the top and support it open. Disconnect any wire clips that are attached to the front panel, such as the door switch wires or wiring harness. There may be a zip tie attached to the wiring harness that you have to remove simply by cutting it off. On the inside, remove the front panel mounting screws down along the front inside edge of the panel. Pull the front panel up and out to remove. Disconnect the wires from the light bulb, carefully noting which wires go where, and press the release tab to remove the old light bulb housing. Install the new bulb and assembly by inserting it into the front panel and snapping it into place. Reattach the wires. Replace the front panel by aligning the slots at the bottom of the panel with the support clips. Lift on the front of the drum as you snap the front panel into place. Replace the panel screws and reattach any wiring that you disconnected to remove it. Rotate the top back into place, pressing down on the front to secure the spring clips. Plug it back in and voila! Good luck!
Jul 16, 2011 | Dryers
When i turn on the printer all the lights are blinking, i have reset the printer many times, restarted my computer and nothing has worked to help the problem. I just printed yesterday with this printer...
The Epson Stylus Color 880 has 4 LEDs. If all 4 are flashing or blinking then the printer has a maintenance request error. It means that the waste ink counter has reach its limit. The remedy is to replace the waste ink pads and reset the waste ink counter. You can use the SSC service utility to reset the protection counter. You can download the utility from here http://inkjetprinterhelp.us/epsonSSC.html
You can also use the control paler to reset the counter. Timing is the key to success when you reset the counter using the control panel so keep that in mind. To reset the protection counter using the control panel (front panel):
Step 1.Turn the power on while holdint the following buttons doen. Paper feed, cleaning button. (thr paper out light will flash for 3 seconds)
Step 2.While the paper out light is still flashing press the cleaning button for 10 seconds. The following leds will flash in sequence Ink out lights black and color, Paper out light. Once the printer starts to initilize the counter should be reset. This will reset the protection counter.
Feb 17, 2011 | Epson Stylus 880 InkJet Color Printer
I have a 2002 pontiac aztek. My rear right signal/brake lamp does not work. When i signal left, the front and rear left lights flash normally. When i signal right, the front right light flashes normally...
as for the faster flashing thats as simple as a blown bulb, replace the bulb and see if that fixes the problem, it may fix the lot because the other symptoms you mention are a bad connection, if bulb is fine check the connection isnt loose or corroded over. if it is simply file it back to establish better connectivity,
Jun 22, 2010 | 2002 Pontiac Aztek
Canon S520 printer stopped printing has 7 orange lights before the green light on printer has an error code
Hi ...
light flashing 7 times means that there is an issue with printer head. Try and perform the below steps to reset the printer head whcih might resolve the problem. If this doen not, I would suggest you get your printer checked by a technician.
Reseat the print head
  1. Confirm that the printer is powered on.
  2. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
  3. Hold and slowly move the print head lock lever up and down several times.
  4. Lower the print head lock lever to secure the print head.
    Note: Holding the print head may cause it to not be seated properly. Perform this step using only the print head lock lever.
  5. Close the front cover.
Don't forget to vote if this helps ... Cheers :)
Aug 05, 2009 | Canon Office Equipment & Supplies
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Lexmark E250dn Laser Printer Logo
737 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
